Engine jack point?
Old Jun 24, 2021 | 03:32 PM
Catfish4818's Avatar
Catfish4818
Default Engine jack point?
Hey guys,
I need to raise the motor in our '72 350 about 1/2" to remove a cracked power steering adjustment bracket for welding repair. One mounting point of the bracket is between the motor mount and the engine block, attached with one of the three mount-to-block bolts, so after I remove the long motor mount to frame bolt on the driver's side, I'll be able to jack up the motor and get the PS bracket out.
Are the any problems to be had if I use the balancer as a jack point (with a block of wood as interference)? I don't want to jack against the oil pan, with or without a block of wood, because I don't want to risk denting it.
TIA,
Larry
Old Jun 24, 2021 | 03:35 PM
derekderek's Avatar
derekderek
balancer is best spot. a cherry picker if you already own one is a better option.
Old Jun 24, 2021 | 04:48 PM
Catfish4818
No cherry picker , so balancer it is. Thx!
Old Jun 24, 2021 | 07:24 PM
OldCarBum's Avatar
OldCarBum
You can rent a cherry picker from most equipment rental yards for a few bucks a day.
Much better that lifting on the balancer.
Old Jun 24, 2021 | 07:34 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I'm staying out of this one....i dont wantthe replies to be un-balanced.
Old Jun 24, 2021 | 08:56 PM
interpon's Avatar
interpon
I used balancer and rubber block from quickjack
Old Jun 24, 2021 | 09:04 PM
Catfish4818
You can rent a cheery picker from most equipment rental yards for a few bucks a day.
True! But I'd have what I'd call 'logistical issues' getting the picker to me, and then back again.
I think my plan is safe - the motor will be 'up and down' twice. Up once to remove the bracket, and then quickly back down. And then up a second time to reinstall the repaired bracket, and then quickly back down.
And since I've NEVER had a problem with ANY of my plans working EXACTLY as they should, EVER, what could possibly go wrong with this plan, right? Yeah, that's what I thought - I'd better be REAL careful...
Old Jun 24, 2021 | 09:06 PM
Catfish4818
THANK YOU!! I have a QJ! I'll use one of those blocks! Had not thought of that!!
Old Jun 24, 2021 | 09:24 PM
interpon's Avatar
interpon
post 4
https://www.corvetteforum.com/forums...ce-79-l82.html
Old Jun 24, 2021 | 09:43 PM
Catfish4818
You had a b**** of a time!
To Engine jack point?
