Rebuilt engine won't start
Old Jun 26, 2021 | 08:59 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I doubt it. You can check your oil and see if you lifted a cylinder head or lost a head gasket....other than fluid in your oil you should be okay
Old Jun 27, 2021 | 12:05 AM
BernieM's Avatar
BernieM
Car is cooled - oil looks clean - took all I had after a few beers not to go try and start it up again - be at it fresh tomorrow - thanks all for the help
Old Jun 27, 2021 | 09:59 AM
derekderek's Avatar
derekderek
you did not do damage. if engine is full of hot coolant the only damage it did was to your sleep. you keep running it until all coolant boils out? now you done damage...
Old Jun 27, 2021 | 11:34 AM
BernieM's Avatar
BernieM
Thanks all (even the comments about the frozen tundra - 90 degrees here in Toronto today) - car started up perfectly today - sounds freaking awesome with the 383 - can't wait to go for a ride later
Old Jun 27, 2021 | 11:48 AM
derekderek's Avatar
derekderek
stop. it got too hot. do not leave the driveway until you have gone over the cooling system and double checked engine timing. post pics of rad, fan, etc.
Old Jun 27, 2021 | 12:17 PM
bluthundr's Avatar
bluthundr
I disagree - it got too hot because the car was not moving (air blowing through it) and you were holding it at 2k sitting still. A box fan helps, but it can't match the volume of air going by while driving. Not a big deal. Take it for a drive and I'm sure your water temp will be fine.
Old Jun 27, 2021 | 01:04 PM
Rescue Rogers
Jesus christ you bunch of babies...Yes it got hot because he was breaking it in. My headers were glowing red hot when I broke my big block and it puked some coolant too.... big deal. Quit making **** up and let the guy go drive his car
Old Jun 27, 2021 | 02:09 PM
derekderek's Avatar
derekderek
idling in the driveway is simulating stuck in traffic. without the worry of pushing it to the side and getting towed. if it won't hold temp idling in the driveway wouldn't risk it. that is why i wanna see his fan and shroud.
Old Jun 27, 2021 | 02:16 PM
7t9l82's Avatar
7t9l82
My mother is 96 and was born in Alberta, my brother in law in British Columbia so light hearted. Jabs at Canadians is just that.
Comments on north Carolina's bbq however is serious 😂
Old Jun 27, 2021 | 04:06 PM
Rescue Rogers
who was idling in a drive way.......no one in this thread. He was breaking in the engine for 20 minutes, then tried to cool it down with a fan and went to move it when it stalled......
Old Jun 27, 2021 | 05:21 PM
sullyman56's Avatar
sullyman56
I’m glad to hear he got it running long enough to do the break in and I think he shouldn’t worry too much about driving it.
Old Jun 27, 2021 | 06:55 PM
BernieM's Avatar
BernieM
Thanks guys - already been for a short ride - rough acceleration - timing light is at my cottage - would you suggest advancing or retarding?
Set at 10 degrees before TDC but I have a new cam
Old Jun 27, 2021 | 09:03 PM
  #33
sullyman56's Avatar
sullyman56
Is it a rough idle? Do you think it could be an issue with your carburetor?
Old Jun 27, 2021 | 09:19 PM
  #34
BernieM's Avatar
BernieM
No carb was recently rebuilt - bogging and sputtering on acceleration - I assume I need to advance it - just want confirmation so I can adjust by hand and then I will take it to my nearby shop so they can fine tune with their light
Old Jun 27, 2021 | 10:08 PM
  #35
sullyman56's Avatar
sullyman56
Just because your carburetor was recently rebuilt doesn’t mean that it was done correctly or that it’s currently set up correctly for your engine. It’s possible that it could be a fuel delivery issue, old gas that you already said was in the tank for nine months or related to timing. I’m just throwing things out there, but considering the problem you had with fuel earlier it’s something to think about.
Old Jun 27, 2021 | 10:10 PM
  #36
BernieM's Avatar
BernieM
Gotcha - agreed - the guys that rebuilt are the "go to" for all of the greater Toronto area - my drive today was to get fresh gas in the tank so that should be resolved but will have shop look at carb too
Old Jun 27, 2021 | 10:18 PM
  #37
sullyman56's Avatar
sullyman56
Good plan. Let us know how it turns out.
To Rebuilt engine won't start
Old Jun 28, 2021 | 03:34 AM
  #38
derekderek's Avatar
derekderek
To retarded very little power and runs hot. Too advanced burns pistons. Take something else to the cottage to get the timing light.
Old Jun 28, 2021 | 11:39 AM
  #39
BernieM's Avatar
BernieM
Think it was a bit retarded - advanced by ear today and it ran much smoother - temps were fine - think that may been part of the issue for it running hot during break in - at the shop - will let you know their comments
Old Jun 28, 2021 | 12:15 PM
  #40
Rescue Rogers
Good news. If you didnt hear it pinging on the way to the shop you should be fine
