1981 Corvette Vibration
Old Jul 5, 2021 | 01:37 AM
foxyshilo's Avatar
foxyshilo
6th Gear
Default 1981 Corvette Vibration
Good evening. I have a 1981 Corvette with a weird vibration issue. When i start my car (and keep it in park) and push down on the gas pedal to rev the engine i can feel a weird vibration feeling in my gas pedal and steering wheel. Its like my engine is running rough but it sounds fine. My car was running great the day before but all of a sudden this started. Any ideas what this could be. I though that it might be a bad spark plug causing the engine to misfire which in turn causes the vibration. Any other thoughts?
Thank you,
Old Jul 5, 2021 | 07:57 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Could be lots of things. What happens when you drive it? how about rev it in neutral? Any more information you could possibly add?
Old Jul 5, 2021 | 11:06 AM
76-Vetteman's Avatar
76-Vetteman
You say there is a vibration and the engine ‘sounds fine’. So I take that to understand there are no new or strange noises attributed with the vibration?
I have had belts that became bad and began breaking apart. This caused vibration but no squeal. I have also had a motor mount go bad, and pushed engine vibration into the frame. The engine mount job is the diminish a lot engine vibration.
More information would be helpful.
Old Jul 5, 2021 | 11:41 AM
Mrvettenick's Avatar
Mrvettenick
Without feeling it, I would look into ignition. When was the last time you changed plugs and or wires? Is the car original. or are there modifications?
Old Jul 5, 2021 | 01:04 PM
7T1vette's Avatar
7T1vette
Check the condition of the engine motor mounts and the transmission mount. If they are old, the rubber is likely disintegrating and may be weak/gummy or broken. This will cause the engine to 'wiggle around' some and give you random vibration issues. If you have one or more broken mounts, there is risk that the radiator fan COULD 'walk' into the radiator and destroy it, should you require instant WOT or heavy braking. So check it out before any damage is done. You can use pry bars and wood blocks to see if there is excess movement or if you can see separation in the mount rubbers. If the motor mounts are good, the trans mount could cause such vibrations, but you wouldn't need to worry about fan-to-radiator damage.
Old Jul 5, 2021 | 03:37 PM
foxyshilo's Avatar
foxyshilo
6th Gear
Thanks all for the assistance. My engine was completely rebuilt. Has a new top end kit from Edlebrock. Also a new Edlebrock carb. I just replaced the plugs 4 months ago. All spark plug cables are new but I did notice that one of the cables has a nick in the outer jacket. I will replace that one. I’ll check the motor mounts today and see if any of the bolts are coming loose but the mounts are also new. The vibration occurs in all gears with I including neutral. Belts are also all new.
Old Jul 5, 2021 | 03:44 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You cannot physically check the stock two piece motor mount without using a long pry bar to lift up on the engine to see if it is separating.....the mount can be bad and look just fine.
Go around at idle and start pulling plug wires one at a time......if you get a wire that when pulled does not cause the idle to drop some.....you found your miss. Replace that wire, plug...check cap terminal, etc......
Jebby
To 1981 Corvette Vibration
