90 Degree Cable Adapter - Lubrication
Old Jul 10, 2021 | 03:41 PM
VanHanlon's Avatar
VanHanlon
Default 90 Degree Cable Adapter - Lubrication
Hi everybody,
I'm in the process of some speedo work on my '74 coupe (L48/M20/3:36, FWIW), and I have one of those old-fashioned 90 degree cable adapters with no grease fitting. I cleaned the cable and jacket and then lubed it with graphite on the bottom 2/3. My problem is that I haven't been able to find information about what to use for the adapter. Chassis grease? Lithium grease? Motor oil? Gear oil? Graphite? EVOO?
Thanks in advance!
Old Jul 10, 2021 | 04:02 PM
lars's Avatar
lars
The best solution is to get rid of the adapter and run your speedo cable in the stock location with stock routing...
Old Jul 10, 2021 | 08:19 PM
VanHanlon's Avatar
VanHanlon
Hi, Lars. Would the stock routing be in my assembly manual? Why would this have been added to the car? From what I see, losing the adapter would require quite a bend in the cable as the tailshaft housing is rather close to the tunnel wall.
Thanks,
Jonathan
Old Jul 10, 2021 | 11:08 PM
Plasticexperience's Avatar
Plasticexperience
I used Mobil synthetic grease
Old Jul 11, 2021 | 09:42 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would use a little grease if you can get it to the gears. I have to use one on my 5 speed to reverse the cable rotation, and it gets lube from inside the case...Dont know if its supposed to but it does
Old Jul 11, 2021 | 10:56 AM
kansas123's Avatar
kansas123
I re-clocked my distributor so that the cable pretty much comes straight out. I think there might have been a GM bulletin that came out about this way back when...
Old Jul 11, 2021 | 12:17 PM
Sayfoo's Avatar
Sayfoo
I used wheel bearing grease. Been good for 25k miles and10 yrs.
Old Jul 11, 2021 | 03:39 PM
Rescue Rogers
( in a whispered tone) Pssst, hey he's talking about the speedo
Old Jul 11, 2021 | 04:13 PM
kansas123's Avatar
kansas123
As Emily La Tella would have said, Oh, that's different....Never mind.
Old Jul 11, 2021 | 04:47 PM
Rescue Rogers
or Rosanne Rosanadana......good stuff!!!!
Old Jul 11, 2021 | 05:33 PM
theandies's Avatar
theandies
That's what I was going to say.
To 90 Degree Cable Adapter - Lubrication
