Longer rear wheel studs
Old Jul 14, 2021 | 12:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Default Longer rear wheel studs
A couple of members here have posted their longer stud installs.....The Money Pit and someone else.....can't remember. Anyway, I am pulling the trailing arms and bearing/hubs and now is the time to do this.
What do you have and what did you use for studs? Pics?
Thank You!
Jebby
Old Jul 14, 2021 | 12:37 PM
76strokervette's Avatar
76strokervette
Arp 1/2 studs in 31 spline Toms outer. I believe studs have ford pn.
Old Jul 14, 2021 | 01:10 PM
gkull's Avatar
gkull
I have the Tom's outers 17 splines with 1/2 inch longer studs.
17 because I'm using the big stockish type half shafts. Also 17 spline super yokes that are bulletproof.
there has been a discussion way in the past about strength differences between 17 and 31 splines. It's like discussing a fine threaded grade 8 bolt to a lesser threaded bolt and it really comes down to the psi strength of the metal. Like 220,000 psi ARP studs. If they are the same tensile strength hardened metal there's a mechanical advantage to more splines, but the ultimate shear strength is roughly the same
1/2 inch studs were rule required and I have Center Line wheels that use Acorn tapered lug nuts
Old Jul 14, 2021 | 02:07 PM
76strokervette
Here is some axle spline info. https://www.markwilliams.com/not-all-axles-equal.html
Old Jul 14, 2021 | 07:21 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I have 1/2" diameter, 3" long ARP studs. Had to open up the holes a little, I selected studs with a small spline to make life easier.
Old Jul 14, 2021 | 07:33 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
True..you have to be careful about getting the splines with the correct "thickness per spline" or else it will be a battle to drive the stud into place.
And IF O.P. is reusing his hubs he can buy "extra-long" studs (rather than having to search for correct-length studs)...
cut the length to suit his needs...
hand-grind the angle onto the starting thread before installing them.
Old Jul 14, 2021 | 07:57 PM
GTR1999's Avatar
GTR1999
ARP wheel studs, as mentioned, Summit has them. 1/2-20 x 3" I use them all the time and they work the best. They are shown the picture above but one detail in the picture is missing.
Old Jul 14, 2021 | 11:22 PM
Barry's70LT1's Avatar
Barry's70LT1
I used stock size 7/16-20 x 3" ARP. (100-7701) https://www.summitracing.com/parts/arp-100-7701
The knurl was slightly larger than the stock stud knurl, made for a really tight fit, so I enlarged the hole in the hub with a 15/32 (0.46875) drill. I made a jig to keep the drill bit perfectly aligned.
Old Jul 15, 2021 | 12:52 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
4130 chrome moly 1/2"x3 ARP
Old Jul 15, 2021 | 10:12 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I looked at this Part# but nobody on planet Earth has them......
Still looking at available options......maybe another ARP number.....or another brand.
Jebby
Old Jul 15, 2021 | 10:28 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Looks like I can use these Moroso studs.....just have to make sure the back of the rotor is countersunk (easy on the Bridgeport).....
They are .480 as opposed to the stock .475...are 8740 material, and have the bullet nose on them.....cool.
https://www.summitracing.com/parts/mor-46150
Jebby
Old Jul 15, 2021 | 01:38 PM
ignatz's Avatar
ignatz
A word of caution. For looks I went with extended lug nuts with finished ends. Maybe 3" or so. You can't quite tell from this angle. Anyway, turned out they just bottomed out before seating the wheel. I really thought the wheel had seated, but it hadn't. I bought 1/8" spacers which did the trick.
Old Jul 15, 2021 | 06:04 PM
Barry's70LT1
Jebby
I checked out the Moroso studs. Interesting that Moroso gives a bold warning about NOT to use with spacers. https://www.moroso.com/press-in-wheel-stud46150/
I use a 1/2" spacer with the ARP studs (ARP does not have that warning). Does Moroso know something that we should know, or are they just covering their back side.
Old Jul 15, 2021 | 06:20 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
They are 100% covering their ***…..it’s an 8740 bolt with a knurl flange…what would be the reason not too….I mean, to a point?
Jebby
Old Jul 15, 2021 | 06:45 PM
OldCarBum's Avatar
OldCarBum
I had Gary install the ARP 1/2" studs in my Tom's axles.
I didn't want the long lug nuts so Gary cut them down so a standard length lug nut will work.
They came out really nice.
Old Jul 15, 2021 | 11:00 PM
GTR1999's Avatar
GTR1999
These are the studs to use. What advantage do you have staying with 7/16 studs?
Old Jul 16, 2021 | 07:21 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
All I was looking for was more thread engagement.......I am never going to launch hard enough to need a 1/2" stud.....plus I would have to drill the hub to 5/8" and possibly the wheel and it is tapered seat. I am going to scratch buying Tom's hubs too.....I simply am not making that kind of power and need to keep my self in check as I am already down the rabbit hole of changing ****.....
I need longer studs, that's it.....the Moroso ones are stronger than what is on the car currently. This car might run high 11's on slicks......
Jebby
To Longer rear wheel studs
Old Jul 16, 2021 | 09:09 AM
69autoXr's Avatar
69autoXr
I've used the Moroso's for a long time, never a problem.
Old Jul 16, 2021 | 10:01 AM
GTR1999's Avatar
GTR1999
Jebby
I hear you.
Yes the axle flange will have to be drilled to accept the ARP 1/2 bolts, the rotor holes too. The rabbit hole is deep with old vettes as you know. Moroso has good parts no question, we use some of Rick's parts and they are good quality.
So if you are in the11's with slicks, what is the diff like? If it's stock it will last awhile but you might want to check the posi case and prep it to make last longer.
Good luck with it.
Old Jul 25, 2021 | 05:07 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
I’m thinking about putting longer studs for my build. Will these work with any c3 rear hub?
