I have a '73 L-48 and have just put on a new performer manifold, long tube headers and had the carb rebuilt by Lars (it already has a little bigger cam and rebuilt, slightly decked stock heads). I also followed Lars' distributor timing instructions and added his VAT. It idles great. The problem I am seeing is when you increase rpm to about 2000 to 2800 (in park, open headers) the timing mark increases as it should to a steady 36 degree advance. After 2500 or so the timing mark gets a little jumpy in the advance direction and it sounds like it is breaking up a bit with some exhaust back fire.
FYI did the same before and after new plugs, points, coil and Mr Gasket advance kit with silver springs. Dwell is right at 30 degrees. I don't know what happens with load because it is still on jack stands.. I am going to get the exhaust put on next week. Will back-pressure and load help?
It has been 25 years since I used a timing light, (but is like riding a bike) I just don't remember a "jumpy" advance timing mark.
Normal? Any ideas thoughts? Could my distributor be messed up?
Check your harmonic balancer. If its the original, the rubber breaks down and the inner and outer portions begin to separate. It will become impossible to properly time the engine.
10 buck piston stop tool from amazon, jegs, ebay, whatever. points. so we know it is not a module or an MSD box acting up. dwell stays at 30. so i assume points aren't bouncing from a worn out spring. maybe it is psychosomatic and the car needs Dr. Phil and not a mechanic...
I assume this is a stock distributor. If so.....how are the bushings for the weights and the pins? Are the weights nice and tight on the pins and swing freely?
The dwell is good so the points are not bouncing......
Hard to say what the backfire is at this point.
Anytime I see a new or recent Intake installation with a backfire, I question the method of the installation.
Having said that, are you sure you used enough quality sealant on the Intake gaskets? And both sides of the gasket?
Without a good seal, those gaskets can leak top side, around the ports and blindly along the bottom of the gasket. This scenario could result in a very lean condition on some cylinders, thereby causing a backfire issue. A vacuum leak causes a backfire 90% of the time.
The upper portion of the gasket can be checked with the engine running, for leaks. But along the bottom of the gasket, at the lifter valley, its almost impossible to evaluate. A vacuum tester could show a wacky needle, plugs maybe oil fouled.
With a high output coil and small cap distributor the spark can "cross fire"; jump from the rotor to an adjacent post on the cap. A cheap cap-rotor combination with large clearances can exacerbate this problem.
This is demonstrated in this video with a cheap Pertronix distributor.
Thanks guys, New Blue Streak cap, rotor, coil, Ill take the distributor apart and check everything for play - Lars had some good thoughts. I only used Permatex on the intake gaskets at the water jacket and on the china wall. It idles great with no surge with break clean. I'll let you know by next week. Keep em coming.
Another thing you can check is proper grounding of the engine and distributor. You need zero resistance from the battery negative to the block and heads and distributor. I've gone as far as to add a #10 wire across all that with clean threads for the bolted connections and stainless steel serrated washers.
Same symptoms with new and old points, cap, cond, rotor, coil. Harmonic balancer checked out with TDC. I think if the balancer was "slipping" it would not be spot on TDC at rest again. I would think it would probably make the mark "jump" but the engine wouldn't respond poorly. Brand new Ground strap with very cleaned up contacts (learned that with the the starter). I'll look at distributor ground, but new manifold/oil pump and very clean hold down bracket is probably making good ground. I don't think I'll really know anything until I get the exhaust hooked up and drive it. I don't have much time between work and then it being too too late to start it with little kids at neighbors in bed. I may just buy a new distributor. I could send it out but I want to get on the road.
PSA - Wear Ear protection when you have open headers this thing is loud.
I'll post when I figure it out. I love detective work.
Reason: Typo
Yes stock - 70K miles. It has a new Mr Gasket advance kit- acts the same with any combo of springs. I may feel some play where the plate is attached to the vacuum advance. Lars suggested my looking there.
when doing the intake i like to silicone the gasket to the heads using china wall gaskets as alignment tools. no sealer on top of gasket. set manifold on and let sealer harden. pull manifold and check that gaskets stayed where they belonged and are there to stay. remove china wall gaskets, sealer up front and back. your chouce if you want to put sealer between gaket and intake.
Don't like the sound of that. I know guys have refused a sealer on Intake ports for decades.
Some get away with it. Most do not.
Not me man. I enjoy applying Edelbrocks Gasiniche, Permatex Right Stuff & Permatex Clear on the gaskets.
I do not enjoy having to do it two days in a row.
If the Intake Gasket leaks on the bottom edge, near the lifter valley, a vacuum leak will NEVER show up by spray testing the top side.
Its a blind vacuum leak. And the only indication is sometimes a oil mist fouling the plugs, or wonky vacuum gauge reading.
