Control arm
Old Jul 24, 2021 | 05:40 PM
Williamhibberd's Avatar
Williamhibberd
Default Control arm
Any tips on how to remove big bolt on rear of lower control arm? I am hoping that I won’t have to dismantle too much in order to gain access to the top bolt. Anyone have a preferred way of doing this? Thanks all.
Old Jul 24, 2021 | 08:23 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Maybe a little more specificity: the bolt that goes through the frame uprights in front of the rear wheels? Or the bolt that goes through the lower ears of the trailing arm that supports the lower shock mount and alignment strut rods?
Old Jul 24, 2021 | 10:32 PM
Williamhibberd
Sorry, yes. I am working on the front lower control arm. The bolt in question is the bigger one at rear of arm.
Old Jul 24, 2021 | 11:20 PM
69L88's Avatar
69L88
Why are you removing the bolt? Know that it is holding back a LOT of spring force.
Old Jul 25, 2021 | 03:09 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
It's a bolt and a nut. put a wrench on top, a socket with a ratchet on the bottom, unscrew. And yes, I certainly hope you have removed the coil spring first.
Old Jul 25, 2021 | 06:10 AM
Williamhibberd
Yeah, everything is dismantled, spring, shock, etc. I guess there is no getting around removing steering fluid reservoir, etc, to gain access to top of bolt. I’m really looking forward to all new bushings and lower springs.
Old Jul 25, 2021 | 07:03 AM
4-vettes's Avatar
4-vettes
from under the car slide your wrench in-between the resivor and frame. I'm certain I never touched my power steering resivor when removing my A arms. the bolt can just stay in the frame.
Old Jul 25, 2021 | 09:53 AM
jmc3367's Avatar
jmc3367
I literally just got done with this. You need the offset wrench. You could probably do it with a regular wrench. Depending on your situation the bolt will probably be seized to the control arm. Use lots of pb blaster. You will have to nudge the transmissions lines out if the way on the passengers side. At least I did on my 81
Old Jul 25, 2021 | 10:08 AM
69L88's Avatar
69L88
4-vettes sums it up perfectly.
Old Jul 25, 2021 | 10:48 AM
Williamhibberd
Fantastic! It can be done. I will work towards that solution. Thank you!
Old Jul 25, 2021 | 10:51 AM
Williamhibberd
That’s so great to hear! I can spend my energy shopping for a new wrench instead of redundant disassembly. I will focus on drivers side first. The AC compressor worries me a bit on the passenger side but I’ll worry about that later. Thanks!
Old Jul 25, 2021 | 11:13 AM
lars's Avatar
lars
The bolt/threads are often corroded. Use a 1/2" drive impact wrench on the bolt while holding the nut with the wrench.
Lars
Old Jul 25, 2021 | 11:21 AM
Kerschmolar's Avatar
Kerschmolar
For that spot I used a low profile socket (with an external hex on one end) and engaged it with a wrench.
Old Jul 25, 2021 | 02:53 PM
Williamhibberd
Lars
Thanks Lars
Old Jul 25, 2021 | 02:54 PM
Williamhibberd
Good tip, thanks!
To Control arm
