Speedometer with 18" Wheels
Old Jul 27, 2021 | 01:00 PM
Eric-'s Avatar
Eric-
Default Speedometer with 18" Wheels
Hi all,
I recently bought a 73 automatic. The speedometer is off because of the 18" wheels. Is this an easy fix, any help is appreciated!
Old Jul 27, 2021 | 02:06 PM
SteveG75's Avatar
SteveG75
Wheel size has nothing to do with it. Tire height is the driving factor. 27" tall tires are stock. Also, changing to a different rear end ratio will throw your calibration off.
If the speedometer is off, you may need to replace the speedometer gear where the cable goes into the transmission. Exact gear will be dependent on tire size, rear axle ratio, and type of transmission.
'73 should have a Turbo 400. More info:
https://www.motortrend.com/how-to/ca...-speedometers/
Old Jul 27, 2021 | 02:09 PM
augiedoggy's Avatar
augiedoggy
easiest fix is to put the correct diameter tires on as mentioned above.. otherwise the trans speedo gears need to be changed or a gps speedo installed.
Old Jul 27, 2021 | 02:12 PM
Eric-'s Avatar
Eric-
Great article, thank you. It is a Turbo 400.
Old Jul 27, 2021 | 02:29 PM
SteveG75's Avatar
SteveG75
One of the problems is that GM used different drive gears in the transmissions, so choosing the correct driven is dependent on the drive gear.
Suggestion. Pull the speedometer cable from the transmission and ID the current driven gear. If your speedometer reads fast, then you need a gear with more teeth to slow the cable down. If it reads slow, you need less teeth. Get a selection of the gears and try them out. I had to do that with my T-56 Magnum conversion and the perfect gear was actually one tooth less than what the calculator gave me.
https://www.chevyhardcore.com/tech-s...to-correct-it/
Old Jul 27, 2021 | 02:50 PM
Eric-'s Avatar
Eric-
Awesome, thank you!
To Speedometer with 18" Wheels
