Radio wiring harness decode
Old Aug 3, 2021 | 04:32 PM
dprather's Avatar
dprather
Default Radio wiring harness decode
The previous owner put in an after market amp and chopped up all the wiring. I did an internet search to decode what wire does what. The results for 1982 C.E. showed colors I don't have such as pink. Can anyone help? Also, why did they use so many yellow wires.
Old Aug 5, 2021 | 08:40 AM
7T1vette's Avatar
7T1vette
I believe yellow indicates that the line is 12vdc, switched and fused. Lots of things get powered that way. Orange is fused, but not switched, I believe. Red is straight 12vdc all the time.
So, red, orange, yellow are the primary ways power is used in the C3.
Old Aug 5, 2021 | 09:37 AM
bmotojoe's Avatar
bmotojoe
You have a memory feed harness and a power feed with speaker harness. 2 different harnesses.
The cut Lt.BLU and Dk.BLU wires look like they once went to rear speakers.
LINKS.
Memory Feed:https://www.lectriclimited.com/connector-radio-105916
Power and Speaker Harness:https://www.lectriclimited.com/connector-radio-105915
To Radio wiring harness decode
