Help me identify under dash wiring
Old Aug 14, 2021 | 06:06 PM
Hippoposthumous's Avatar
Hippoposthumous
4th Gear
Default Help me identify under dash wiring
I have a 74 454 with a few issues. None of the gauge lights work. The only interior lights that work are the blinker indicators.
Might be relevant:
Whenever I touch the wiper switch, I get badly jolted. It's not static, it's a jolt and it happens every time. It has a crappy aftermarket stereo head unit. I've only had the vehicle for a week, so I can't help with the history.
What are the things I've marked 1-5? What looks incorrect?
Thanks for the help!
Old Aug 14, 2021 | 06:59 PM
Richard454's Avatar
Richard454
1)Courtesy light holder- not correct replacement- for 78 later
2)Headlight over- ride switch
3)Trip odometer switch- or an added on power wire behind it?
4)Courtesy light holder
5) Rear window defroster
Old Aug 14, 2021 | 07:07 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome
You need an owners manual.
It says 'headlight cover' but you pull down and the bulbs stay off but the lights pop up.
Make sure that you push the odometer lever up after turning it.
For no dash lights check that the tail light and instrument fuses are good.
Find useful information here:
https://www.gmheritagecenter.com/gm-...tion-kits.html
Old Aug 14, 2021 | 07:27 PM
Eliredandblack's Avatar
Eliredandblack
Search on the Forum and download a wiring schematic for a 1974 car. I would address the wiper switch that is causing a Shock, immediately, that’s how electrical fires and burnt wires begin. By a disconnect for your battery so you won’t be working on any circuits that have are live (voltage), please don’t ask me how I know! The replacement of fuses on C3’s are a fun job either.
Old Aug 14, 2021 | 07:58 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I believe you push up on the trip odometer know and then rotate it to zero out the numbers. Should have a rubber **** on the end of it.
Old Aug 14, 2021 | 09:19 PM
Peterbuilt's Avatar
Peterbuilt
You are correct, push UP to zero out the odometer and pull DOWN when done.
Got my up & downs mixed up!
Old Aug 14, 2021 | 09:25 PM
Peterbuilt's Avatar
Peterbuilt
http://www.keystonestatecorvetteclub...tte%201974.pdf
Old Aug 15, 2021 | 05:32 PM
Hippoposthumous
4th Gear
I will definitely look for one, thanks!
Old Aug 15, 2021 | 05:34 PM
Hippoposthumous
4th Gear
That's very good advice. I've just moved to HI and don't have tools here yet, but I'll pick up a small kit, an electrical tester, and a disconnect.
To Help me identify under dash wiring
