Ignition Mudule
Old Aug 23, 2021 | 11:54 PM
SEVNT6's Avatar
SEVNT6
My original module lasted 44 years, 77k on the odo.
I replaced it with a $40 NAPA Echlin unit that's U.S. made & it came with the grease.
Make sure all 4 connections are tight too. A loose one can burn out a mod...
Old Aug 24, 2021 | 12:10 AM
Richard Daugird's Avatar
Richard Daugird
When I get around to it, I will double check EVERYTHING . Thanks for all the help guys, When I first started driving, these were just 5-10 year old cars and didn't break much. Can't remember now what exact problems we had or how we fixed them. Glad we have the internet now and a million gearheads around the world to help each other out! I raise my glass!
Old Aug 24, 2021 | 12:11 AM
Richard Daugird
Oops, I forgot this wan't my thread, sorry, I hope you got the info you needed!
Old Aug 24, 2021 | 09:33 AM
HeadsU.P.'s Avatar
HeadsU.P.
Originally Posted by TL79C3
Where would I find thermal paste
Some of the "modges" came with the compound. Most do not.
Last time I saw a tube of Heat Sink was at Radio Shack. And we all know what happened to those stores.
If Amazon sells it, it will be on EBay too, maybe cheaper, maybe free shpg. (Amazon sells on EBay, its a secret)
Old Aug 24, 2021 | 09:56 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I keep a tube in my tool box at work….just about all industrial machine CPU’s have a heat sink on the board….in Texas, it is important that the grease is not ten years old….a common thing I do is remove the heat sinks and clean off old shitty caked grease and reapply new….this tube came from Altex Computer supply in San Antonio.
Jebby
Old Aug 24, 2021 | 11:08 AM
Richard Daugird
Can you store that stuff in the refrigerator to make it last? I think a tube would last me a lifetime...
Old Aug 24, 2021 | 11:32 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Just put it on the shelf next to the Anti-Seize…or some other **** you will never use….
You can buy a $5 pack at the parts store that has barely enough in it too….
Jebby
Old Aug 24, 2021 | 11:46 AM
Richard Daugird
I hear ya, I can splurge $15 on a tube. I actually use anti-seize quite often. I do WAY more mechanical stuff than electrical, and almost NEVER electronics.
Old Aug 24, 2021 | 06:42 PM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
Ok Vetters.....
I have read some good suggestions and solutions. But what it really seems to come down to is.......Its the nature of the beast. Which is to say.
#1......Its a shitty ignition design
#2......If anyone has had the same module for 40+years, in my opinion is because quality control and quality of materials were much better back then
#3......Carry a spare at all times
#4......There is no 100% fail safe solution
#5......Its a total crap shoot on how long the next one is going to last
#6......Listen to the girlfriend when she says "Im tired I don't want to cruise Woodward anymore"
But seriously. What it comes down to is..... purchase as good of a module and coil as you can. (most expensive doesn't necessary mean the best). Use heat shrink paste/grease. Good ground on the coil, and maintain the secondary circuits.
Thank you Vetters
Cruise Safe
Old Aug 24, 2021 | 06:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I had good luck with the OEM that came in the car.
It started acting up in little tach needle movements.
At the same rpm when the car was cold the needle would bounce a few hundred rpm until it was fully warm and drove normally.
20+ years and 50k miles.
Changed it out with an AcDelco didn't last long and almost did not let me get home.
Had to cool off a little then it would work enough to get home.
Could have been my fault with the temp paste but a coil went out around the same time.
Then the mag pickup cost me a new module.
I carry an extra one now. I am real lucky I didn't have to be towed.
So make sure the coil, pickup, and connections are good.
Old Aug 24, 2021 | 07:15 PM
Mrvettenick's Avatar
Mrvettenick
Originally Posted by Gunfighter13
Yep 4 pin module uses red and yellow wired coil and 7 pin uses red and white wired coil. If you swap them you end up with more heat on the module and a shorter module life.
Those coils are electrically the same. The only difference is the direction of the windings, and that was to match the pick up coil, so the magnetic fields don't interfere. A red and white coil has to go with a green and white pick up, A yellow and red coil goes with a green and yellow pick up.
Old Aug 24, 2021 | 07:48 PM
Peterbuilt's Avatar
Peterbuilt
WOW! I learned something today, thanks.
Old Aug 24, 2021 | 08:12 PM
  #33
HeadsU.P.'s Avatar
HeadsU.P.
40 years on a car part doesn't mean much. What if the car only has 3,000 miles on it? See what I mean?
Its the mileage that counts. Run time.
Old Aug 24, 2021 | 08:49 PM
  #34
Gunfighter13's Avatar
Gunfighter13
You may want to do some research on that part of your statement, they are not the same. Not even close. Maybe your chevy engine turns in the opposite direction than every other chevy out there. Same pickup field generated in the same direction.
Old Aug 24, 2021 | 09:34 PM
  #35
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
No I do not see what u mean..... Because I was referring to a comment that stated 44 yrs old and 77000 miles..... See what I mean
Old Aug 24, 2021 | 09:56 PM
  #36
Gunfighter13
Here are the specifications for the red and white coil and the red and yellow. Pickup coils have green and white wires on sbc and bbc engines. Some people look at the pickup coils and think the white wire is yellow but it is not. Only discolored by heat.
Red and white coils
Primary is .300 ohms and secondary is 8.8k ohms.
Red and yellow coils
Primary is .600 ohms and secondary is 8.9k ohms
Both windings are in the same direction. Pickup coils are the same direction.
Like I said the type of module you have determines the coil you use.
Old Aug 24, 2021 | 10:04 PM
  #37
ebbnflow's Avatar
ebbnflow
ARCTIC MX4 or MX5
Amazon Amazon
if you really want to do your module a cool favor ... mount it Outside of distributor on a dedicated heatsink (as GM did beginning ~1996 w/ Vortec L30 & L31 motors). Use the thermal paste too.
https://www.rockauto.com/info/301/10...mary__ra_p.jpg
https://www.rockauto.com/en/catalog/...eat+sink,11323
To Ignition Mudule
Old Aug 25, 2021 | 11:35 AM
  #38
Richard Daugird
I like this idea, got any pictures of one done that way?
Old Aug 25, 2021 | 12:14 PM
  #39
Mrvettenick
I did my research. I worked on GM HEI systems. I worked for a manufacturer. And just because you disagree, I really don't care. And there's no need to get snotty.
Old Aug 25, 2021 | 12:31 PM
  #40
Mrvettenick
Red and white coils
Tell me where those specs are? And if the windings are the same then why are some of the primary leads are crossed in the cap mount. Also, show me one application where a red/white coil uses a yellow lead pick up. And when I say lead, I'm talking lead connector.
