Which Timing Springs
Old Aug 24, 2021 | 08:34 PM
ren80's Avatar
ren80
Default Which Timing Springs
Getting ready to recurve timing advance per Lars method. I have a stock L48 1980. Does anyone know which spring set to use to get the correct full in at 2500-3000 rpm?
I have a spectre set 5754 and a Mr gasket set 928G. I would like to avoid trial and error if possible. Is there another spring set I should get? Any help is appreciated!
Old Aug 24, 2021 | 08:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
The 928G kit should have come with a very detailed timing chart of what each color spring set would do.
I seem to recall: One Blue. One Silver, maybe.
But others will chime in.
Your timing light will tell the story if its perfect or not. Along with your throttle response.
I barely recall an issue with either the 928 or 929? Something about the plastic bushings be too loose maybe?
Bueller? . . . . . . . . . . . . .Bueller? . . . . . . . . . . . . . . Anybody?
Ferris Bueller?
Old Aug 24, 2021 | 09:27 PM
7T1vette's Avatar
7T1vette
Depends on the brand of recurve kit. I ended up with one soft and one medium with the kit I bought. Don't remember the brand. Two mediums was not enough and two soft springs had timing coming in WAY too soon. That would be where I would suggest you start and adjust that selection based on the results of that attempt.
Old Aug 24, 2021 | 09:44 PM
ren80's Avatar
ren80
This 928G kit came with no info. Its got Black, brass, and 2 sets of silver.
Old Aug 25, 2021 | 12:17 AM
Bikespace's Avatar
Bikespace
I used one light and one medium to get all in at 2800 rpm in my 79 L48. The weights are also a variable, hopefully your dist is in good shape, and you can make it all work without changing them out.The best way to do it is a bit of trial and error.
Do you have a dial-back timing light, and/or an harmonic balancer marked with MSD timing tape?
Old Aug 25, 2021 | 09:13 AM
HeadsU.P.'s Avatar
HeadsU.P.
Really? No info? No chart?
Somebody was slacking in production & packaging.
Old Aug 25, 2021 | 09:39 AM
MelWff's Avatar
MelWff
If you have a 928G spring kit it is the wrong kit.
It is for points distributors.
You need a 929G which is for HEI.
Old Aug 25, 2021 | 03:13 PM
ren80's Avatar
ren80
Ok the 929G kit. Do you know which springs worked?
The dizzy is stock with stock weights. I do have a dial back timing light.
Old Aug 25, 2021 | 03:47 PM
MelWff's Avatar
MelWff
Read this article
https://www.motortrend.com/how-to/ba...i-distributor/
To Which Timing Springs
