Running hot
Old Aug 29, 2021 | 08:24 AM
Nedalley's Avatar
Nedalley
1st Gear
Default Running hot
Hello, I am new to this forum and hope to get some help with my 79 corvette. It seems to run hot. I have changed the thermostat and flushed the radiator. I also changed the sending unit to make sure it was working properly. After a 20 minute drive in 90 degree weather the fluid in the reservoir is boiling. My next step will be to replace the radiator but I’m not sure if it needs to be changed. Any suggestions/comments?
Old Aug 29, 2021 | 08:41 AM
interpon's Avatar
interpon
Yes
i suggest copius pictures especially around radiator and fan seals your car details, manual auto, any mods etc…
also where your timing is at..
overheating how? When? Pic of front lower spolier..
Old Aug 29, 2021 | 08:57 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It just may be needing a new radiator cap. What is the temp gauge running at. I second the call for pictures. Make sure you have a full fan shroud and you need all the seals around the radiator and from the front air dam up to the radiator as Interpon said.
Old Aug 29, 2021 | 09:05 AM
Bikespace's Avatar
Bikespace
Low hanging fruit: Have you confirmed the temperature with an IR thermometer shot at the upper radiator hose? What is your timing set to? Can you squeeze the lower radiator hose and confirm that the spring is there to keep it from collapsing?
Photos will help us help you, and years from now will help other people searching the Forum.
Old Aug 29, 2021 | 09:08 AM
HeadsU.P.'s Avatar
HeadsU.P.
First, I will give you the basics on your issue, then maybe you can narrow it down.
Overheating at speed is a Coolant Circulation issue.
Overheating at idle is a Air Circulation issue.
What do these mean? If you are traveling at 60-70 MPH then obviously you are getting plenty of air. But the coolant system can't keep up. Why?
Could be restricted block / head passages, collapsed lower radiator hose, faulty W.P, bad thermo, etc, etc.
If you are standing still, the waterpump and hoses are likely keeping up, good water circulation etc. But you have loss of cooling with not enough air through the radiator. Why?
Once a yr, take a compressed air wand or air gun and blow air backwards, through the Rad. Lots of crap lodged in the fins.
Then you have all the foam seals around the Rad to contend with. Is the clutch fan working? Fan belts tight? Shroud in place?
What is your gauge reading, by the way?
Old Aug 29, 2021 | 10:08 AM
derekderek's Avatar
derekderek
one air flow detail that is the exception to Heads Up's rule. the chin spoiler. it is needed to push air up into the area in front of the radiator. without it most air just blows under the car. your 20 minute drive: around town, lights and traffic? or 20 minutes on the highway at speed? and when it gets warm, if you get up to speed do you see temp drop almost immediately? or is it staying hot at 60 mph?
Old Aug 30, 2021 | 08:11 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Where is your timing set at?
Jebby
Old Aug 30, 2021 | 11:06 AM
lars's Avatar
lars
Timing is the greatest contributor to hot-run issues. If you do not have enough initial timing, and if you are not running vacuum advance correctly hooked up, your engine will run hot. Check and fix your timing before chasing other tails.
Lars
Old Aug 30, 2021 | 04:33 PM
twinpack's Avatar
twinpack
Also check to make sure the lower radiator hose is not collapsing. Squeeze the hose to verify there is a spring in the hose.
To Running hot
