Hydro boost help
Old Aug 29, 2021 | 04:34 PM
atthemattin's Avatar
atthemattin
Default Hydro boost help
So I’m having a bit of an issue finishing up my hydroboost. For some reason I can seem to get it to lock up the front wheels or ever get the braking power I was expecting. I’d drive around and try and lock up the wheels and I just couldn’t get it to.
here is what I have:
I have the stock proportioning valve in it
I got a brand new wilwood tandem model 260-8556
i have the d8-6 and d8-4 calipers on it
i got a hydroboost out of an Astro and I’m getting 13/16 extension with the pedal extended
i have another proportioning valve on the tandem master
i called willwood and the guy seems to think that my stock proportioning valve might be the reason. Went to the Bette show and talked to the wilwood rep and he said it’s the fact him not getting an inch of extension from the booster and I should go manual brakes. I don’t have much of a gap between the master and the tandem, so I think I finally got that fixed. Is their more I need to do with the pedal? Adjust it more? Or is the hydroboost just not giving me enough Tavel?
Old Aug 29, 2021 | 06:28 PM
ChrisLSx's Avatar
ChrisLSx
General advice/input only:
- If you have changed your calipers and master cylinder to non-factory (piston sizes/bore), then the proportioning valve must also change. The factory proportioning valve is designed to work with the factory setup, so when you change anything (away from the factory specs), then the factory proportioning is not longer relevant.
Replace the stock proportioning valve with adjustable propositioning valve.
Old Aug 29, 2021 | 08:27 PM
cagotzmann's Avatar
cagotzmann
I setup the MC / brake booster a little pre-loaded (no clearance) for faster brake response.
I have the same setup but using the factory vacuum power booster. Too lockup the front brakes you need great brake pads / no air in the brake system. With wilwood calipers in the rear it is difficult to bleed properly. You will need to stand the calipers vertical and bleed off the car.
You will also need to bleed the MC While on the car. Like this
Get the last bit of air out from the brake master cylinder. - CorvetteForum - Chevrolet Corvette Forum Discussion
Once this is clear of air, Then bleed the rear calipers off the car, then bleed the front.
you dont need to change anything since the MC / Calipers are the same as factory specs. If you have sticky front 18" wheels you will need high friction pads to lock up.
Old Aug 29, 2021 | 10:05 PM
atthemattin
so I bought a motive power bleeder to clear the air. Seems to do well. I dont see myself still having to lift the rear, or will it still trap air?
Old Aug 29, 2021 | 10:07 PM
atthemattin
yeah, I have the willwood proportioning valve on it. I’m going to remove the factory one and hold onto it for now. You think that would cause this?
Old Aug 29, 2021 | 11:23 PM
ChrisLSx's Avatar
ChrisLSx
I don't know the specifics of your setup (which is why I offered my statement as general info only), but you stated that you have the original/factory spec proportioning valve. As I stated, the original/factory spec proportioning valve is designed to work with a original/factory spec brake system. When you no longer have a original/factory spec brake system, you shouldn't be running the original/factory spec proportioning valve.
I run adjustable proportioning valves on anything I hot rod/mod (provided it doesn't have ABS). If you install an adjustable valve, set the rear almost off, and still can't lock the front then you need more pad at the front (or have a really bad mismatch of master and caliper sizes).
Old Aug 30, 2021 | 11:16 AM
cagotzmann's Avatar
cagotzmann
I use pressure bleeding as well, this never clears the air in the MC,
I bleed the MC first, then pressure bleed the calipers.
so when installing a new MC, blench bleed first, install in the vehicle, fill the calipers using pressure bleeding, once the system is full, bleed the MC while on the car, and finally re-bleed each caliper.
To Hydro boost help
