Nylon timing gears
Mine:
I posted a thread when mine failed to warn others. Back in the early '70's I was hearing from friends to replace the plastic coated cam gear. Of course I was like others and just waited.
https://books.google.com/books?id=ag...20gear&f=false
Jebby
Most times engineers do not design something to fail in X time. They will design stuff to a minimum life. Given that most cars in the 70's and early 80's were rust buckets by the time they had a 100k miles on them, there wasn't a lot of value in designing a timing set to go more than that. And this isn't just an American car thing. Consider the great Honda reliability mystique. A wonderful thing. But well into the 2000's, and maybe still, I don't know, on their engines if you failed to replace the timing "belt" at 60,000 miles (80k in later models) you would find yourself replacing an engine instead. And that was a $600 job back 20 years ago. So, whose timing set was better?
Don't take this to mean I think this was a good timing set. But looking at the lifetime of the rest of the car's components, there was a good chance it would outlast the useful life of the car. The reason it's a problem for us is that these survivor vettes may have racked up a lot of miles, but they weren't often out in the rain, and snow, and salt. The 87 Olds I had that ate its 3800 V6 thanks to one of these plastic toothed cam sprockets had 111,000 miles. At that point though it had rust holes right through the rocker panels and lower fenders both front and back, suspension was in sad shape, etc. I bet most of the cars of that vintage and earlier still had the original plastic toothed sprocket when they were junked.
If you go to my thread you'll see that at 90k miles on my vette there was very little wear on and only a couple cracks in the nylon teeth. This might be because I always used STP back then when oils were not as good as today.
On the issue of replacement I used an Edelbrock double roller. Per my thread, there is some bulge on block behind the cam sprocket which will need to be ground down some to clear the wider chain.
Chevy Power Manual recommended cam timing gear. Also used for HD marine applications. If you have your timing cover off you should put one of these gears on to replace the plastic toothed gear. If the chain is shot you can do that while you are at it too.
41 years, 90k miles - how'd that happen.
And that's not a one off. My cousins had a '74 also bought new. One of them was 18 years old when he bought it. 2 years later he sold it to his brother who was 16 years old at the time, same age as me. Imagine highschoolers in a vette. Believe me, we beat it, yes we. My brother had it one day for running around our high school. I had it for a couple dates. We put headers on it and ran it with open headers until for a few days. Later we snapped a motor mount. Then blew the TH400 tranny out of it. In '79 my cousin was in college in Vegas and wanted the car out there. Covered all my expenses to drive it out there from NY. I was 20 years old - How to you think I drove it. He kept it for another 5 years then sold it still running.
Basically my whole extended family was driving GM cars - the cousins I mentioned above owned a Chevy dealership. I don't recall a single one ever toasting an engine due to cam sprocket failure - and we would have known since my grandfather and his cousin owned a garage, so I pretty much knew what all my extended families cars were up to. The only one I ever saw fail was in my own 1987 Delta 88. And per my previous post that was at 111k miles and 11 years old, at which point it was a rusted hulk.
The gear did it's job relative to the expected lifetime of cars of the era.
9-1110 for big block
9-1145 for small block factory roller
As far as it being a bad design....that answers itself.....in the 80's about everyone I knew had one fail.....100,000 miles was the number....some sooner. Add a cam and better springs and you are flat out just an idiot for using it.
Not worth debating as it didn't do the number one job it was supposed to.....cut down on noise. It makes me laugh how GM and others thought they could run these reliably......they must of been in contract with manufacturer and couldn't get out. Just a complete piece of **** idea that we are all glad is dead.
I don't care what Chevy Power book says either....that single chain is a piece of **** too.
Jebby
Just so everyone understands this. ALL 1966-91 Corvette PRODUCTION small blocks used an aluminum camshaft sprocket with nylon teeth, a powder metal crankshaft sprocket, and a Morse-type chain. ALL, every one ever made. GM ceased selling the nylon tooth camshaft sprocket in SERVICE more than 40 years ago in favor of the cast iron sprocket. But PRODUCTION applications used the nylon tooth. If one finds a 1966-91 small block that doesn't have one, then that engine has a replaced sprocket.
ALL 1965-74 Corvette big blocks used an aluminum, nylon toothed camshaft sprocket, a powder metal crankshaft sprocket, and a Morse-type chain. This includes L-88, ZL-1 and LS-6. GM NEVER offered a cast iron camshaft sprocket or steel crankshaft sprocket for big blocks in OEM SERVICE. The only sprockets ever available were nylon camshaft and powder metal crankshaft. If one finds anything but the foregoing in a 1965-74 big block, then it's been replaced with non-GM parts. For the better, of course.
New engine take-off timing sets from GM circle track crate engines were available 2 years ago and they were affordable at that time. I just can't justify the current cost for these anymore. Keep your eyes peeled and you may find a good deal.
I actually bought a Cloyes C-3001K replacement timing set and it looks like a screaming bargain by comparison. Steel gears and heat treated chain. Should work well on your flat tappet engines.
Also, it wouldn't surprise me if the wear on the teeth is not continuous, but instead they look good like mine for some period and then fail catastrophically. You can see the cracks on some of teeth in mine. I suspect once one of them snaps, the ones on either side would go to hell pretty quickly and it would progress rapidly from there. In other words, maybe I was 10k miles from a problem hitting the 100k magic number in Jebby cited in his experience. Or maybe I was just 1 mile.
I mentioned in a few other threads that my job is failure analysis, so I can fun with this all day. But on whether or not it was good design, certainly not by today's standards. But back then it provided the lifetime most people expected. My only real bitch about the design in general was that unlike the Hondas which listed timing belt replacement at 60k miles, GM never listed a timing set replacement at say 80k. Despite my 87 Delta 88 being a rust bucket at 111k miles, it still ran well and got be back and forth to work. I would have been OK dropping a couple hundred into it to keep going for a couple more years.
