Serpentine Conversion Big Block
Old Sep 10, 2021 | 11:41 AM
zr1topsportsman's Avatar
zr1topsportsman
Default Serpentine Conversion Big Block
Is anyone using the Kwik performance system? I’m not worried about having to notch the crossmember but more concerned about control arm clearance. The only aftermarket conversion that guarantees fit I can find is the March kit. I do not have A/C.
Old Sep 10, 2021 | 11:29 PM
JohnRR's Avatar
JohnRR
I have the March Kit on my '73 BB. I don't like it because it has two belts and it doesn't have spring loaded belt tensioners. The inboard belt has to be tightened by moving the power steering pump. The bolts on the pump dig into the soft aluminum bracket. The outboard belt get tensioned by using a supplied rod that separates the alternator and the A/C pump. PITA!
Old Sep 12, 2021 | 01:33 PM
68/70Vette's Avatar
68/70Vette
I'm interested in this Holley serpentine kit to be available at the end of this month.
https://www.holley.com/products/engi...parts/20-242BK
Myself, I wouldn't be interested in notching the crossmember. It's weak enough as is. They are subject to bending, bowing in, due to engine weight especially with a 600 pound plus BB bouncing up and down. If a serpentine system required notching the crossmember, I'd look at getting a small diameter pulley for the crank damper. I was getting close to getting a March system, which required notching the crossmember. and I asked if they could sell me one with a smaller crank damper....they said No! I have the GM Performance Parts catalog serpentine system on my 68. I bought a small crank pulley for it because I thought the stock pulley was overdriving the accessories, particularly the water pump.
Old Sep 12, 2021 | 03:24 PM
JohnRR's Avatar
JohnRR
My '73 BB has the March system on it and it did not require me to cut anything!
If you're worried about the front cross member flexing, add a Spreader Bar. It fits with the March system too.
John
Old Sep 12, 2021 | 04:51 PM
BigBill94's Avatar
BigBill94
I second this feedback. I'd look at Billet Specialties or ConceptONE with an auto-tensioner and a single belt if I was a do-over - the March system was put on my car by the PO, it's great once you have it set right.
Old Sep 14, 2021 | 07:14 PM
zr1topsportsman
By notching I don’t mean cutting away metal and leaving a void, but boxing it back in. When done correctly it actually can strengthen the area. Thanks for all the feedback and when available the Holley setup may be the best thing to purchase. I have all the factory pieces to make the Kwik performance conversion work so for now I am going to try it. I will give feedback when completed.
Old Sep 18, 2021 | 03:45 AM
Danish Shark's Avatar
Danish Shark
This will not fit in the Corvette. You need a remote reservoir.
To Serpentine Conversion Big Block
