461X heads on L48
Old Sep 12, 2021 | 09:44 AM
psmock's Avatar
psmock
3rd Gear
Default 461X heads on L48
ok guys I am new here and have been out of the game for some time so I am rustier than an old nail.
I recently purchased a 1976 L48 corvette and I want to help out the lack of HP on the low end. Not worried about top speed will be driven on the street.
I have a set of 461X heads for it 2.02/1.60 ported intake and exhaust valve guides with screw in studs matching set of heads
have long tube headers to be installed
have Holley 650 dual feed carb
HEI ignition
I am looking for what cam to use I am guessing 1.5 rockers and what head gasket thickness?
Stock motor only has 39,XXX miles too gonna trust the lower end lol.
Thanks in advance and if I asked the wrong question or didn't ask the right question feel free to call me an idiot that's how we learn
Old Sep 12, 2021 | 03:46 PM
stingr69's Avatar
stingr69
Assuming you do not need the threadded holes in the ends of the heads?.......
Use a .015" steel shim head gasket with copper spray sealant on it. You need a cam for LOW RPM.
If that is not enough you can add more gear to the rear.
After that, you need a longer stroke. 😈
Old Sep 12, 2021 | 04:06 PM
psmock's Avatar
psmock
3rd Gear
Yes I didn’t even think about the accessory bolts. So back on the shelf they go and now in search of a 64cc cylinder head.
Old Sep 12, 2021 | 05:21 PM
ebbnflow's Avatar
ebbnflow
Drill and tap 'em ... you or shop.
Old Sep 13, 2021 | 09:53 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Use the Comp 262 cam for automatic.....the 268 for manual.
Jebby
Old Sep 13, 2021 | 10:43 AM
wilcar's Avatar
wilcar
Jebby
I think Comps old school 260 HE cam maybe the cam Jebby is referring to. It is 212 212 duration @050 110 lsa. The Isky old school 262 super cam is 208 208 @ 050 108 lsa I think either one would work for an automatic.
Old Sep 13, 2021 | 10:45 AM
psmock's Avatar
psmock
3rd Gear
Thank you will look into the Comp cam
Old Sep 14, 2021 | 04:03 PM
Fast81's Avatar
Fast81
Since you didn't mention an intake yet and want 64cc heads, I'd go vortec heads with a vortec intake
To 461X heads on L48
