Engine needs 60 degrees initial timing. Help me understand.
My base timing is +13 with 87 octane.
Have you checked cranking compression? Can i assume the vac. advance is disconnected when you test base timing?
I first assumed you had a digital timing light and it was at fault, but then noticed you have a standard light. And you checked TDC it so that eliminates the balancer.
I assume that means you are using the timing marks on the new degreed balancer?
Cranking compression is ballpark about what I would expect for a 8:1 CR engine.
And you are correct the wire location on the distributor does not matter, they are 45 degrees apart, #1 will fire to the closest terminal. What is very interesting here is you seem to be MORE than 45 degrees off. But yes please stop it at tdc and check rotor cap to cap #1 terminal alignment. Which ever terminal you want to place #1 on is entirely up to you, and spark plug wire reach length. Confirm please.
Since you can check TDC accurately, and make a pointer, I assume you can degree in a cam with a degree wheel, that is what I would check next. The popping out the exhaust could be either very retarded timing or extremely lean.
But since degreeing the cam is a lot of work check 2 easier things first:
- What is the timing curve set up like? Idle, total, and at what rpm? How much does the vac can add? Does the vac can add it at idle? (ie: manifold vac or ported) Measure it and post.
- How is the carb AFR? Check and see if the idle mixture screws can drop idle rpm (50+) in BOTH directions, in and out. Confirm and post.
- Then set them for best vac reading.
It could also be that the duration is just too large for a 8:1 CR engine. This CR really needs short duration cams and careful LC and ILC settings to get decent cylinder pressure. It may be that it just has too much overlap for the CR. I have seen multiple engines that run very very poorly with that combo. And it is very difficult to figure out the cam while in the car. With a degree wheel and a dial indicator set to .050" valve lift you can get reasonably enough close tho.
The decently high 17 in idle vac seems to indicate a milder type cam, but it could be being artificially "propped up" by incorrect can timing.
Hopefully Jebby will chime in too. He is very good at tuning & combos. If not PM him.
In terms of the distributor, while we are 45 degrees off at the crankshaft (since that is where the advance is being measured), from the distributor's perspective we are only about half a post off. In other words, at 60 degrees of timing advance, the rotor ends up being about 30 degrees past the number 1 post at TDC. I did this test already and confirmed that when the crank is at TDC, the rotor is roughly 20-30 degrees past the number 1 post (between 1 and 8) which agrees with the timing light reading.
It's looking like the front of the motor will have to come off again to get the cam degreed properly. The PO left no information about it so it could be anything. Regarding your points:
- Not much has really been tuned in terms of mechanical advance since it's really hard to curve a distributor when a motor is backfiring like crazy and possibly running dangerously at too much advance... what I do know is that the mechanical advance appears to be working and adds around 20 degrees of advance when the motor is revved (depending on what springs are used, it's all in at around 3000 RPM). During all timing tests the vacuum advance was left unplugged (and plugged off at the carb), but ordinarily it's on ported vacuum. It is working though as it was checked with a vacuum pump.
- The idle mixture screws don't really seem to help the problem, I'll have to check if they can affect the idle by 50 RPM
Yeah this was another thought that crossed my mind. I'm concerned that whoever built this engine bought a big cam and high flowing heads/intake, which are not going to work will with the stock compression ratio. I'll have to see about degreeing the cam and seeing what's really in the car. I'll get back to you on your other points, thanks!
How much does the vac can add? Shoot for 10-12, more is not good. Add a limiter if necessary. And then please move it to a manifold vac port.
But neither of these sound like your issue.
Check carb mixture screws, then degree cam.
Neal
The only reason people have to move the dizzy orientation is when the vacuum canister is clocked way out of proportion.
And Nab Yags, you don't have to tear apart the front timing cover. In my opinion, if that cam was truly one tooth off, it would act as a "No Start" issue. Yours not only starts but idles.
And 160 lbs of compression would not be likely be happening with timing chain set off a tooth.
