Engine Temp
Old Sep 21, 2021 | 12:29 PM
Winger76's Avatar
Winger76
Default Engine Temp
Almost have the new insulation and carpet down, but the 76' runs warm by the floor pans. 50mph plus stays under 200, but if I'm driving around for a while and sit for more than 5 minutes at idle the engine temp get closer to that 260. I have the shroud around the radiator and the fan is running at least it is when I start it up. Could the radiator have anything to do with that? ...wondering if I should take it over to the jiffy lube to have it flushed?
Old Sep 21, 2021 | 12:59 PM
HeadsU.P.'s Avatar
HeadsU.P.
If you are going to own a Vette, you need to learn how do the basic jobs to maintain it. A coolant flush is very easy.
And after watching a couple YouTube vids on scam auto shops, J.L. would be the last place I would go. But its your money / car.
Just about all C3s did run hot at the floorboards. Why? Because the heater core refuses to shut off. Why? Because some engineer thought it would be ideal to have the heater core shut-off, vacuum operated.
So your first job after the flooring is to install a heater core shut-off valve (NAPA $25) Put it inline of the 3/4" hose going to the core. Open it in the fall. Close it in the spring.
Your overheating at idle is a air circulation issue. (Overheating at speed, is a coolant circulation issue)
Check foam seals around the Rad. Belts tight? Clutch Fan operation, etc.
Think "air" or lack of it. What's blocking or diverting the air?
Old Sep 21, 2021 | 01:49 PM
C6_Racer_X's Avatar
C6_Racer_X
The thread title is "Engine temp", but the discussion seems to be about interior temp at the floor.
If engine temp is an issue, especially if it's cooler at highway speeds and warmer at idle, test your fan clutch.
Safety warning: When doing this test, be sure to keep your fingers, beard, hair and any other body parts you've grown attached to out of the moving belts and spinning pulleys.
Easy fan clutch test. Get the thin cardboard tube from a roll of paper towels. After driving for a while (engine up to operating temperature), park the thing, let it sit idling but not moving for a minute or two. Watch the temp gauge, don't let it overheat. Then open the hood. Very carefully, holding one end of the cardboard tube, press the other end of the tube against the back side of the spinning fan. If you can stop the fan with the cardboard tube, the fan clutch is shot.
Although the older fan clutches did last a long time, modern ones are pretty short lived. It's now strongly recommended that the fan clutch be replaced at the same time the water pump is replaced. Both have a similar service life now, and a failure in either one can take out the other one.
Old Sep 21, 2021 | 02:03 PM
Yadkin's Avatar
Yadkin
Originally Posted by HeadsU.P.
If you are going to own a Vette you need to learn to how do the basic jobs to maintain it.
And Jiffy Lube?
Old Sep 21, 2021 | 03:42 PM
HeadsU.P.'s Avatar
HeadsU.P.
Originally Posted by Yadkin
And Jiffy Lube?
Leave off the "J".
Old Sep 21, 2021 | 04:08 PM
Haggisbash's Avatar
Haggisbash
First thing I would do is get an IR meter to verify the exact temp of the coolant to verify the dash gauge is accurate as well as check the into and out of temps of the coolant going through the radiator.If the temp gauge checks out then the temp differential of the coolant going into and out of the radiator will give you some clue as to whether it needs flushed. Next would be the fan clutch and the seals around the radiator as well as ignition timing(are you running the factory smog timing or the settings suggested on this forum including manifold vacuum for the distributor vacuum advance).
Shutting off the coolant circulation through the heater core will help with the interior heat ( I used a vacuum operated valve for this so I can open and close it using the centre console controls). Is the foam collar in place to reduce hot air from the motor getting blown along the transmission tunnel?
Old Sep 21, 2021 | 04:27 PM
C6_Racer_X's Avatar
C6_Racer_X
Leave off the "J".
I always figured the "J" was just graffiti.
Old Sep 21, 2021 | 04:35 PM
1Hotrodz's Avatar
1Hotrodz
At 230°F coolant temp, your fan clutch should be roaring, from air movement, trying to cool the engine. Is it?
Old Sep 21, 2021 | 05:00 PM
Bikespace's Avatar
Bikespace
I don't have much to add. I scrolled down to say these exact things. The IR temp gun check is vital (and handy for so many things). Do you have run-on or dieseling if you shut down the engine?
Please post some photos! DIY coolant flush isn't too hard, if you can get under the car. The block plugs are easy to reach with the exhaust removed.
Here's a link to the foam horse collar, with a diagram.
https://www.zip-corvette.com/68-79-s...on-collar.html
Old Sep 21, 2021 | 05:02 PM
interpon's Avatar
interpon
Post some pics of of fan / radiator area etc.. @Winger76
Old Sep 21, 2021 | 05:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
I bet a flush will help; learned on bottom feeder cars to remove the fan once a yr and from the backside with a garden hose blow all the crap out of the fins makes a huge difference.
May want to look into an aftermarket alum. radiator, they are not as much as they once were and totally worth it.
Old Sep 22, 2021 | 09:03 PM
ebbnflow's Avatar
ebbnflow
don't futz around w/ just a flush ... CLEAN IT ... look for CF member noonie posts about GM CLEAN procedure.
https://www.corvetteforum.com/forums...car-yet-2.html
Old Sep 23, 2021 | 10:36 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Check your fan clutch......
I had my 98 Mustang GT flushed at Jiffy Lube once.....the **** was brown in the system. I watched them do it......they have a powerful vacuum that sucks every last bit of the old **** out of the system.....they used a treatment chemical....ran the car and did the suction thing again.....filled with green and distilled that I brought them. $100. It was worth it to me as I didn't want to do it......
Of course, YRMV......the flush at Jiffy Lube is exactly as good as the person running it......just know what you are getting before hand....
Jebby
Old Sep 23, 2021 | 05:45 PM
L-46man's Avatar
L-46man
Buy Service manual
AIM manual
Wiring diagram
Vacuum diagram.
Fundamental knowledge is key here.
Personally, I WISH to hear/see the following words...
I've read the service manual
I looked at all the cooling system diagrams.
And finally 'we're talking about ENGINE TEMPS not floor temps.'
Yes, in a way they ARE related; To whit
When the fan is barely operating most of the VERY hot air is going under the car...heating up the tranny tunnel and floors. When the fan is pulling the proper amount of CFM's the engine temp and floor temp will go down.
Fix the cooling issue and the floor temp will follow.
Old Sep 24, 2021 | 03:50 AM
Eliredandblack's Avatar
Eliredandblack
I took my 2001 Camaro to a radiator shop and they used compressed air (with water) to really get the crud out of the OEM Radiator. That was the best $ 70 I ever spent, way better than a garden hose and bottle of radiator cleaner. They also fixed the leak and pressure tested the OEM radiator on my 73 SB, a lot cheaper than a replacement. A large part of their business centers around trucks/specialized equipment, where replacement radiators are not easy to find.
Old Sep 24, 2021 | 07:16 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I just want to add that EGT's are the #1 cause of interior heat on a C2-C3 Corvette.......incorrect timing specs can send EGT's 300-400 degrees higher than normal and where is the exhaust? Where does that heat go....?
It also effects coolant temps.......
So to the OP......where is your timing set at?
Jebby
Old Sep 25, 2021 | 01:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
Had Jiffy Lube flush a radiator on an 87 G20 van I figued it was worth a shot
There was so much crap that came out I could not believ eit...guy did a great job and yes it was worth it
ran the bejeezus out of that during hot Ca summer months as a work vehicle it never ran warm . Could they sprout a leak maybe this one didnt
edit: ditto on the garden hose/can of secret sauce you pour in its kind of a waste. Those machines they use are super effective.
To Engine Temp
Old Sep 25, 2021 | 02:03 PM
Winger76's Avatar
Winger76
Great advice, I am turning the wrenches and learning quite a bit, I know enough to have moderate success. ...not setup to change out all the fluid, so in this case easier to pay extra to have it flushed. Thank you for the tip, putting the valve on the list. Appreciate the time you took to respond.
Old Sep 25, 2021 | 02:06 PM
Winger76's Avatar
Winger76
Checking this out tomorrow!!! Thx.
Old Oct 11, 2021 | 06:44 PM
Bikespace's Avatar
Bikespace
Any updates?
