Broken rocker stud boss
Only problem with welding cast with possibility of liquid leaks is that it is only about 10 percent efective against leaks. I have had to drill and tap holes that were in a position to leak.
Best weld is with the same material.
Seen some good posts here, but I guess I was off on the cast weld.
DOM
