Broken rocker stud boss
Pulled all rocker studs out. Started tapping all bosses for threaded studs.
Noticed on the second head that 1 boss is broken.
The damage is about 4 threads deep. I think there are around 7-8 threads that fully engage below it.
should I repair this? Perfect excuse for aluminium heads afterall? Or machine the boss down for a stud (studs?) With a nut?
And, where did all the metal go? Lifter valley? Pan?
And if your wife is reading this, any repair would not be safe around the children, dog or garage / house.
Better shop for new. Ah shucks. Tough luck.
My choice would be to clean the complete head ,then the area. the head area has to be heated and athe stud screwed in and cold. Weld and remoce stud. If you can't remove stud then pin it with a taper pin. Back in the day we ised taper pins to keep the studs from pulling out when heavy springs were used.
Cast is tricky to weld and a experianced welder is needed. I use a silicone bronze rod for cast. then it needs to be peened with a sharp pointed peener to stretch the molecules. If not peened then it will crack. If it doesn't unscrew then you actually have what you want.
Dom
they're 487x heads, nothing super sexy.
don't have kids, but do have my trust 4 legged helper. Aluminium heads it is!
The much safer way to strenghthen the rocker arm stud is to cut 3/8" off of the top of the boss and install a stud with the itegral hex base that you tighten up to the pushrod guide plate. The obround pushrod holes in the head need to be drilled open wider and you use the guide plates to align the rocker arm with the center of the valve stem at final assembly. It looks like you need a machinist to do this. If the damage can mostly be removed with a 3/8" deep cut, the head can be saved and strengthened better than new. You will need a new set of guideplates and a new set of HARDENED pushrods for use with guideplates. Not the cheap rebuilder pushrods with the pressed in "ball bearing" looking ends. Around ~$120 US. 5/16" are fine and be sure to match the guideplate slot size to the pushrod diameter.
Time to cut the boss down 3/8" and add the proper hexed shoulder studs.
Boss cracked when rocker arm stud was tightened.
This way is possible but I do not advise it. The pushrod to valve stem alignment is not adjustable this way. Too late now since the bosses are already cracked anyway.
I don't think a machine shop would charge to much for this, they have been doing this for 50 years.
Stock 1970 LT1 head with original screw in studs & guide plates.
Press in stud head being cut down.
Notice how the cut down boss almost goes down to the level of the headbolt boss. I do not think your chip goes far beyond that so yours could be saved, if desired. It may be the cheaper way out, or maybe not. Your budget and desires are just as important.
I would price up a set of aluminum heads, and compare to fixing yours, include pushrods, etc. You may find the total cost is not too much more. And newer chamber design al heads will give you an instant 30 HP just by the one part swap alone. And if you increase the compression, even better.
Oh, and as you are in Belgium, could you find a machinist over there comfortable with or has experience doing this?
I've looked into getting them machined. When I'm picking up my block I'll be taking the heads to get the machinist to take a look.
I have been looking at aluminum heads, AFR ENFORCER looks affordable. https://www.airflowresearch.com/195c...cylinder-head/
Do they always need guideplates? Or is this only for when you use a solid lifter cam with non self aligning rockers? (If I'm correct I think the original rockers are all self aligning except those on the LT1?). I don't have a lot of experience with these rocker styles. All my European cars Im used to working on are either OHC or use a rocker shaft. Thanks in advance
Do not run a "guided tip" self aligning rocker arm WITH a guide plate.
You need to purchase an adjustable length push rod tool so you can measure for the custom length push rods you will need to order.
FYI, No OE C3 rocker is self-align.
As indicated, with aftermarket heads like AFR, you are likely to have most success with guide plates + hardened push rods + NON self-align rockers.
As said, you MUST correctly measure for proper pushrod length Before ordering any pushrods. Depending upon manufacturer, PRs usually available off-the-shelf in 0.050" Or 0.100" increments; which is close enough for street motors. FWIW, rocker arms with NO roller tip are less demanding of correct PR length. There are any number of instructions for measurement on web.
And, with any valve train part, it's penny wise and pound foolish to risk chinesium.
- Don't run non self-aligning rockers on a aftermarket head that has no guide plates.
From a GM OEM parts standpoint you can only purchase self-aligning rockers (10089648) as the non self-aligning rockers (3974290) are no longer available. Even the Sealed Power non self-aligning rocker made from GM drawings are no longer available. Used or NOS is the only option for these rockers.
Why? do those SR have HUGE pushrod guide-holes that're part of casting ?
Yup, except for lifters, seems sealed power/SP have dropped all related valve train.
I agree that when the shop does this work they could also just mill a good top surface for ALL the rocker studs by just 'cleaning up' the top surface. Exact boss height doesn't matter as lifters are adjustable.
In terms of hardened pushrods, are they all the same?
comp cam 7812-16 is what I have my eyes on ATM. I've read different storie, some people saying all SBC pushrods are hardened from factory ( someone said to take a file to them and test), some say hardened 1010 steel is fine, some say you NEED chromemoly steel.
I would Not braze the rocker stud boss; there's a fair amount of stress on those bosses. In fact, I wouldn't spend what it'll cost to successfully weld it AND machine it ... because those heads are very poor performers. Get better heads or just find another similar sbc head. They don't HAVE to perfectly match.
7812-16 PRs will be fine for mild sbc. Hardened PRs are Required whenever sbc/BBC has guide plates; otherwise , hardened not required.
