Engine identification
Old Sep 26, 2021 | 05:44 PM
HT1663WB's Avatar
HT1663WB
Default Engine identification
Can anybody help with engine ID? The numbers on the pad, by the water, 121210803 K03 24 CKB
Thanks, Bill
Old Sep 26, 2021 | 06:45 PM
MelWff's Avatar
MelWff
CKB was used from 72 to 74 not for Corvettes.
72 was an L65 used with Th400, 165 HP, 2bbl, A and B body.
73 was an L48, 4spd manual , 175 HP, F, A and X body.
74 was manual transmission 3 and 4 spd,185 HP, F and X body
https://nastyz28.com/gm-chevy-codes/chevy-engine-codes-suffix-2.php
Old Sep 27, 2021 | 12:21 PM
HT1663WB's Avatar
HT1663WB
I think I may have figured it out. The vin on the block is xxxx121210803. That would be 6th digit designates year 1972, 7th digit designates Canada, McKinnon Industries. Looks like it's an L65, (165 hp that had a 2bbl carb and turbo 400 trans).
The K03 24. K= McKinnon, 03=March and 24 = day. Probably came out of a Chevelle still trying to figure that out. MelWff, thank you for pointing me in the right direction!
Old Sep 27, 2021 | 07:44 PM
ebbnflow's Avatar
ebbnflow
now, see if all that jives with casting date.
To Engine identification
