Cold Idle Speed
Old Dec 21, 2002 | 08:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Cold Idle Speed
I have been driving my vette quite a bit since I finally got the engine back in and am very happy. I put a 670 Holley Street Avenger carb on the car and it fires right up the first try every time. :cool: The cold idle speed was about 2000 RPM so I backed it down a notch and now it is about 17-1800 RPM. How low can I go on cold idle, and what speed should it be set at?
Also everytime I park for a few minutes it always goes back to the fast idle speed when I start it back up. What is causing this? Electric choke?
Old Dec 21, 2002 | 09:47 PM
wombvette's Avatar
wombvette
Default Re: Cold Idle Speed (Eddie 96)
The answers are , As low as you want too and keep it running, and Yes the Electric choke.
Old Dec 21, 2002 | 09:59 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm not sure exactly what it should be on the Holley specifically, but on old Q-jet you'd set the fast idle cam to engage when you initially pressed the pedal to the floor on startup. The fast idle cam should engage and hold the car at a higher RPM until the choke starts pulling it off. I think in a car with a bimetal spring type choke embeded in the manifold, as long as the manifold is hot the choke won't allow the fast idle cam to engage. I'm not sure exactly how it supposed to work with an electric choke.
As for your original question I think that 1300 - 1500 rpms would be plenty high enough, but according to my Chassis Service Manual, fast idle is 2400 RPM :eek: for my 69 Corvette with a 4MV Q-jet. That seems a little high to me!
Old Dec 21, 2002 | 10:14 PM
Eddie 70's Avatar
Eddie 70
Default Re: Cold Idle Speed (Smokehouse69)
I looked in my Service Manual and found the same thing. 2400 RPM
I think I may shoot for about 1400-1500 and see what happens. Thanks for the info.
Old Dec 21, 2002 | 10:29 PM
Bullyj's Avatar
Bullyj
2400 sounds a little high to me. The 1400-1500 sounds much better. You could adjust it up and then back it off until it sounds right and then see what your tach says.
Old Dec 25, 2002 | 12:24 PM
jim482's Avatar
jim482
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03 & '06
Eddie,
You can adjust it down pretty low (1000-1200 rpms).
The determining factors are:
1)How does the motor run cold? rough idle etc...
2)IF you place the car in gear from this rpm, does it quit running?
3)have you adjusted your Electric choke any?
To Cold Idle Speed
