L 46 engine
Sep 29, 2021 | 06:21 AM
L 46 engine
Did any L46 motors use the HW block and did any come with solid lifters?
Sep 29, 2021 | 07:34 AM
No solid lifters and what is an "HW" block? if you are speaking of the suffix code, HW is correct for a 69' Corvette 4spd. 350/350.
Jebby
Sep 29, 2021 | 10:28 PM
so is the 964 cam a hyd cam ?
Sep 29, 2021 | 10:34 PM
Quote:
Originally Posted by
DaleAlan
GM# 3896964 is the 350/350 hydraulic flat tappet cam.
Jebby
Sep 29, 2021 | 10:37 PM
DaleAlan
3896962 is the GM part number for a 350/350 Hydraulic cam. Are you seeing a casting number of 964 ?
Sep 29, 2021 | 10:49 PM
Barry's70LT1
You are correct. 3896964 is the
casting number for the cam core….350/350 my oops.
Jebby
Sep 30, 2021 | 07:17 AM
OK guys , the 964 number I’m seeing is a cast number not a part number, thanks for the info.
but that’s the only number I see. . Is there a date code ? And do the lifters have a part number on them?
Sep 30, 2021 | 11:02 AM
DaleAlan
no date code or part number
