383 oil pan
Old Oct 1, 2021 | 02:01 PM
Patches Davidson's Avatar
Patches Davidson
2nd Gear
Default 383 oil pan
I have a 78 Corvette and ordered a crate 383 stroker motor for it. But I can't seem to find a oil pan to fit it does anyone have any suggestions.
Old Oct 1, 2021 | 02:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Who sold you the crate 383? They should be able to tell you which pans will fit.
Old Oct 1, 2021 | 05:33 PM
ebbnflow's Avatar
ebbnflow
if new 383 also has a 2 piece rms, your 350 pan should fit at well. Have you tried it ?
Old Oct 2, 2021 | 09:27 AM
BKbroiler's Avatar
BKbroiler
My 383 has a 2 piece rear main seal and I am using the stock oil pan from my 77 L48 on it.
Old Oct 2, 2021 | 09:47 AM
gjohnson's Avatar
gjohnson
A crate motor w/o a pan??
Old Oct 2, 2021 | 10:20 AM
ebbnflow's Avatar
ebbnflow
FWIW, for generations both short & long blocks typically shipped with little or no tin.
Old Oct 2, 2021 | 09:01 PM
Stormin_Normin's Avatar
Stormin_Normin
I have a 2 piece seal 383 with a stock pan, but I did have to clearance it in a couple spots. 2 piece and 1 piece blocks use different pans and flex plates and flywheels.
To 383 oil pan
