TH400 modulator on '72 350
Old Oct 1, 2021 | 02:56 PM
kansas123's Avatar
kansas123
Default TH400 modulator on '72 350
I replaced rather than adjusted my modulator, and instructions for the new one stated that 'great care was taken to adjust this to factory specs', however now the transmission will not shift out of 1st gear. Just wondering if the new one is mis-adjusted and that enough can be done adjusting to get this tranny to shift again. I have the adjustment instructions and wonder is any members can tell me how much change will be realized by turning the screw 1 turn, 2 turns. I believe I need to turn the screw clockwise to get it to shift and shift smoothly. Thanks for any help with this.
Old Oct 1, 2021 | 03:40 PM
69FASTFUN's Avatar
69FASTFUN
Did you hook up the vacuum line? That's all I could think of.
Old Oct 1, 2021 | 04:35 PM
kansas123's Avatar
kansas123
yes, it's hooked up.
Old Oct 1, 2021 | 05:15 PM
pspicci's Avatar
pspicci
If you didn't already put a hand held vacuum pump on it and see if it holds vacuum. also check your vacuum line all the way to the the other end at the engine and make sure there are no leaks. one time about 25yrs ago when i had toi have my trans replaced the shop forgot to connect the other end of the vac line to the manifold and it would not shift out of first at least not up to 5000rpm.
Old Oct 1, 2021 | 08:43 PM
7T1vette's Avatar
7T1vette
jChances are the "new" modulator should be used as a door stop... Take it back and get one that works.
Old Oct 1, 2021 | 08:54 PM
kansas123's Avatar
kansas123
dang it, didn't occur to me; sure hope I can find the old one, at least it worked better than it's replacement
Old Oct 1, 2021 | 09:06 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old Oct 1, 2021 | 09:13 PM
C3 Stroker's Avatar
C3 Stroker
Another vote for the vacuum line......possibly blocked somehow. If it's hooked up, the modulator will generally work throughout its adjustment range, with the shift points just changing a little.
Old Oct 3, 2021 | 01:14 PM
kansas123's Avatar
kansas123
wasn't blocked, the connection from car to new rubber hose on modulator was bad, was not holding vacuum because of connection sizes. Good to go now
Old Oct 4, 2021 | 10:35 AM
7T1vette's Avatar
7T1vette
Glad it was an easy fix. Also glad you didn't get a 'lemon' with the new modulator.
Old Oct 4, 2021 | 11:05 AM
kansas123's Avatar
kansas123
You and me both brother
To TH400 modulator on '72 350
