Just bore the block??????
Old Oct 4, 2021 | 08:04 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
new block, 4 bolt mains, forged crank and vortec heads.. That is a real good base! especially for 3600!
Old Oct 4, 2021 | 10:06 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Originally Posted by onaqwst
Found a shop close so will take it up there next week and they can pull the engine/etc... This should give me some time to research and see what my options are. Might be a good time to upgrade to a MSD ignition setup too. Should probably change out the fuel pump while I'm at it.
Hmm... Maybe a D.U.I. & save the cash that a MSD would cost
Old Oct 5, 2021 | 12:23 AM
onaqwst's Avatar
onaqwst
Originally Posted by ebbnflow
Nowadays, virtually all crate motors have a one-piece rear main seal (GM changed from two-piece to one-piece '86-'87); their flexplates & flywheels have different bolt patterns and are not interchangeable. You'll need a New flexplate. New flexplate can be had for < $40. GM crate I suggest below has Forged Steel crankshaft and is the newer One-piece RMS design which has a smaller bolt circle than your Two-piece RMS motor has.
Be advised. All GM sbc crates are completely brand new top to bottom. And have the best warranty in the business with No Restriction on where you Must file any claim (sue) if you can't resolve a warranty issue.
Be advised. Crates from either ATK (aka Vege) and BPE have a warranty which Restricts user to file (sue) in Company's State of choice; ATK/Vege = Illinois while BPE = Nebraska. Suggest read the fine print and/or consult Your counselor Before writing the check; because, sadly, sometimes stuff happens.
The BPE motor referenced above has a New block but many (if not most) BPE crates use a remanufactured block which has been bored out to (or beyond) blocks' intended/practical limit.
ATK/Vege crates are similar; some have new blocks while some use a remanufactured block which has been bored out to (or beyond) blocks' intended/practical limit.
When it comes to cranks: Cast Steel is Not Forged Steel. Cast is Cast. Forged is Forged; and is more robust than Cast.
FWIW, GM sells a True 383" (the one you reference) with standard 4 inch bore & 3.800" stroke forged crank.
This $3600 motor: from GM
https://www.gmperformancemotor.com/parts/12691673.html
This roller motor will easily make 300-315 Gross SAE HP on an engine dyno with a good carb & distributor & headers
With a drop-in spring & retainer swap ($140),bigger roller cam swap ($250) it'll easily make ~ 425 Gross SAE HP on an engine dyno; and do it reliably.
Freshen your carb & dist, a new Vortec intake $175 ...DIY I'm seeing under $5K. Cam & spring swap rather easy.
four USA-made billet steel roller cams for sbc
https://www.summitracing.com/search/...rder=Ascending
think long & hard
Maybe I need to get a full part list so I can order soon and make this a winter project...... maybe get my dad involved to have him do something (he's retired) and spark his mechanical brain again... I buy parts, he helps build it.... then I'll pull the motor in the garage and see what happens....
If I have to bump the budget up a bit to cover a few things that is fine.... I still have the stock trans so maybe swap that out next year once I feel out the engine...
Old Oct 5, 2021 | 11:35 AM
ebbnflow's Avatar
ebbnflow
OP
? What year and which model is your C3? Please state now and in any future thread. Lotsa wasteful guessing here from not knowing that.
If it's a 75 thru 80 it came OE with desirable 4-pin GM HEI distributor. If that's what yours has, there's No need to buy DUI or MSD etc; just freshen Your 4-pin HEI.
Same goes for carb, if it's 80 or older, it came OE with desirable Rochester QuadraJet; If that's what yours has; just freshen Your QJet.
Old Oct 5, 2021 | 12:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ditto on a simple HEI will get the job done.
Todays aftermarket heads will outperform most ported factory heads plus they have an advanced chamber design to preventpinging and are just efficient period. Sell the old ones off and step up lotsa power in heads today.
3600 is a steal for a brand new everything (block too) roller cam 383. Managed to spend 18k on mine and its outdated
Old Oct 5, 2021 | 12:48 PM
derekderek's Avatar
derekderek
Agree with above. You wasted money having those boat anchors ported. And that’s the reason you don’t have any power. Your bottom end might even be fine. you don’t know.
Old Oct 5, 2021 | 12:49 PM
onaqwst's Avatar
onaqwst
OP
77 but has a bastard 350sb.. not original...... holley 650 DP, performer intake, cog drive belt system, no ac/smog....
Old Oct 5, 2021 | 12:58 PM
ebbnflow's Avatar
ebbnflow
Yup, ...but GM 12691673 is a Vortec head roller 350 w/ forged crank ... not 383 ... regardless, $3600 is a great value!
Old Oct 5, 2021 | 01:06 PM
1Hotrodz's Avatar
1Hotrodz
How many miles on the engine? And is it a numbers matching car? And if you want to know for sure if your engine is just worn out, and needs rebuilding, have a leak down test performed on the engine. This will tell you the overall condition of the engine. Go from there.
Old Oct 5, 2021 | 05:37 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
If it was me, I would order this:
https://www.gmperformancemotor.com/parts/19418654.html
You can put anything you want on top.
No need to pull the engine again.
Use your original heads and mani, carb etc.
Slowly add higher and high performance parts as money allows.
Old Oct 5, 2021 | 10:57 PM
onaqwst's Avatar
onaqwst
Decisions and time.. a lot of good options thus far. I could do the 383 base since I have a mild cam (no clue on specs) and maybe buy some better heads.... 650 holley DP might have to be upgraded?... could be a good winter project
Old Oct 5, 2021 | 11:13 PM
ebbnflow's Avatar
ebbnflow
JMO
HT383E ... it IS a truck motor & Not such a great choice for a performance car. That's a good motor but a hogtied combo for a performance car. Look at your specs ... it has a baby cam (both motorboat & truck) ... makes tons of torque but puny horsepower (truck motor). Also has a pricey Long reverse rotation water pump w/ threaded snout to fit GM threaded clutch fan (truck motor) ... you won't use that pump and you won't use its pricey distributor unless you also use a truck ECM & injection.
that partial is a poor value ... NO cam or roller lifters nor the dog bones & spider either & no heads ... poor value at ~ $4300
In general, vettes & Long pumps don't fit. Use a pump Like what's on yours now because it'll fit Your brackets & pulleys; any other type pump won't fit.
best value & bang for buck & potential for more giddyup is that $3600 L31 replacement ... the very reasons I suggested it in the first place.
YMMV
Old Oct 5, 2021 | 11:35 PM
  #33
onaqwst's Avatar
onaqwst
JMO
YMMV
Appreciate the feedback..
current situation.. nothing fancy...
Old Oct 6, 2021 | 01:34 PM
  #34
onaqwst's Avatar
onaqwst
thinking about purchasing it this weekend. need to just make it happen at this point. vette isn't going anywhere so mine as well get this project moving... I was thinking of just dropping a few more bucks and doing a full dressed motor, but will crunch number the next few days... I think 7-8k would be my max at this point if it was an easy swap....just dont want to regret it later of not maxing out a SB to a decent performance setup.
https://blueprintengines.com/product...tor-bp4002ctc1
https://blueprintengines.com/product...on-bp35513ctf1
Old Oct 6, 2021 | 05:35 PM
  #35
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
First one! Hands down. Good parts, cubes and 500HP.
What's not to like?
Unless you just gotta have fuel injection. That adds $1000+ but the engine parts are not near as good.
Old Oct 6, 2021 | 05:59 PM
  #36
onaqwst's Avatar
onaqwst
What's not to like?
you think?.... my knowledge on engines is like 1/10... powertools/fabrication is 15/10..hahah.... need to make sure my stock auto trans and diff will be fine... you know... can't replace everything..ahha
Old Oct 6, 2021 | 06:04 PM
  #37
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
What rear gear and trans do you have?
I ask because the bigger engine with more torque will much more easily accomodate a mild torque convertor and mild rear gear, and still run great. A smaller engine needs those two items much more optimized to keep up.
To Just bore the block??????
Old Oct 6, 2021 | 06:51 PM
  #38
onaqwst's Avatar
onaqwst
stock for 1977 (auto). I have not touched these when I tore it all down years ago....
Old Oct 6, 2021 | 07:41 PM
  #39
ebbnflow's Avatar
ebbnflow
warranty dispute ... potential claim venue.
Old Oct 6, 2021 | 07:46 PM
  #40
ctmccloskey's Avatar
ctmccloskey
That is true as I tried ordering a Camshaft from Competition Cams on and they said "most wouldn't work with a 3.36 rear" axle ratio. The Tech support said I would need a 3.60 or higher rear axle. It really limited the choices of a cam for a 427 with a 3.36 rear.
My C3 was delivered with the "economy" 3.36 rear ratio and the four speed it has and is great at getting "Good" mileage even with a Double Pumper on top. Our Corvette club went on a ride one time and I drove from my Home in Virginia about 35 miles to meet them and then 60 plus miles on to a state park. I watched several of my buddies with the 4.11 rears getting gas on the way home. I drove a 427 at 70 plus most of the day and I got home with a bit over 1/4 tank.
Having the right combination makes a huge difference. I like the mileage as gasoline is not cheap like it had been.
