Just bore the block??????
Old Oct 3, 2021 | 10:14 PM
onaqwst's Avatar
onaqwst
Default Just bore the block??????
Been on the fence about a crate engine since everything on my current SB is new.. 650 holley DP, performer intake, plugs/wire/, cog drive belt system/etc, heads rebuilt/ported... Only thing that I haven't touched is the block/pistons. I'm looking to possible just have a engine shop pull it and bore it out or just get a new block/pistons. With what I currently have, I would like to get 400hp or more if possible... I have no getup right now and ready to pull the trigger on just dropping it off to have done.
Old Oct 3, 2021 | 10:19 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Buy a new short block then. Although the old block may be perfectly serviceable. You'd want the block sonic tested to verify that it will take the overbore but if it's never been out it should. With a short block you could get a roller block & 1 piece seals
Old Oct 3, 2021 | 10:24 PM
onaqwst's Avatar
onaqwst
Yeah, I think the block might be the issue, hence why I want to just swap it out. I will look into that, thanks
Old Oct 4, 2021 | 12:52 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
For a shortblock to kill the power....it would have to be severely hurt. Even a smoking engine will run hard if the rest of the parts are right. It probably is a low compression engine...so certainly kicking it up a couple of points will help...but power is in the heads/cam and tune.
You said the heads are ported. What heads? Any flow numbers? What cam is in it?
If you're going to go into the shortblock...no reason to not at least make it a 383.
JIM
Old Oct 4, 2021 | 02:56 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
On mine when I did a refresh a couple years ago. I found the bores all well within spec's. I honed the cylinders and fitted them with new hyperunetic pistons and rings of the same (Std) size, some new crank and rod bearings and reassembled. 5 thousand miles later. Running great, no oil consumption and a fraction of the cost of a new short block.
Just my 2 cents.
Old Oct 4, 2021 | 04:58 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
You want a 50%+ increase in h.p. From what I've read on the Forums your original engine may be pushing it's limit if you modify it that much.
Maybe a new short block (and possibly U.S. made aluminum heads/if the original heads aren't built for power) would be your best bet.
Old Oct 4, 2021 | 07:51 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Hello fellow Michigander.....
Being from the D, you are in probably the best place in the world to have your block machined. How much do you want to do? If you can build it yourself.....have the block machined and buy a balanced rotating assembly from Scat, Eagle or others.....if not, then as mentioned, get a short block from a reputable shop.
If you have a fresh top end....the short block is the best way value and timewise.....
Jebby
Old Oct 4, 2021 | 12:00 PM
onaqwst's Avatar
onaqwst
JIM
I have a mild cam in it... don't know the specs since it was done back in 2003 at my dad's friend shop. There is a shop close to me that seems to be the go to guy since I see a decent amount of hot rods there... I will see if my dad knows the head specs but I know those were torn down and rebuilt. I'm not an engine guy so learning as I go here....
Old Oct 4, 2021 | 12:04 PM
onaqwst's Avatar
onaqwst
Jebby
Yeah, there are a few shops around, problem is just pulling the motor since I blew out my back and recovering from that, so would rather have a shop do it and maybe upgrade a few things. I was looking at a few short blocks kits and might be the best way to go. swap in/out and don't have to worry about 'shop' mishaps....
Old Oct 4, 2021 | 12:45 PM
onaqwst's Avatar
onaqwst
Found a shop close so will take it up there next week and they can pull the engine/etc... This should give me some time to research and see what my options are. Might be a good time to upgrade to a MSD ignition setup too. Should probably change out the fuel pump while I'm at it.
Old Oct 4, 2021 | 01:10 PM
Sayfoo's Avatar
Sayfoo
I've known a few people who have done similar projects and were pretty much disappointed.
You need to research some more, and then, realistically, think about what you expect to gain.
As said above, just refreshing your short block may not be gaining you much, while costing $$$.
Old Oct 4, 2021 | 02:03 PM
onaqwst's Avatar
onaqwst
Just spoke to my dad when he came over last to help me figure it out (he's an OG mechanic so has helped over the years, but getting up in his age so can only do so much)
My heads are 202 and opened up on 3 sides(think that typical). compression is around 125...
could just be a timing/.spark issue....
I'm still thinking a 383-400 upgrade, but will see. with what ever works with what I have on the top end/components ...
Old Oct 4, 2021 | 02:05 PM
76strokervette's Avatar
76strokervette
1st thing is to set budget. 2nd thing is to see what you have. 3rd thing establish goals and go from there.
Old Oct 4, 2021 | 02:25 PM
ebbnflow's Avatar
ebbnflow
Yup!
OP
If yours still has its original pistons & heads; it had Very Low compression when new & it's a near certainty it still has very low compression ... porting & rebuilding heads don't raise compression. Dunno which year or model yours is but (judging by your profile pic) it came w/ low compression large chamber (~76cc) heads and (unless L82) came with low compression dished pistons.
JMO, I suggest a new GM crate motor w/ modern GM Vortec heads; otherwise it'll cost more to rebuild & upgrade yours. GM crate motors have THE best warranty. YMMV
Old Oct 4, 2021 | 02:41 PM
onaqwst's Avatar
onaqwst
Originally Posted by ebbnflow
Yup!
OP
If I can stay under 5-6k for the short block/upgrades/etc, that would be great. I wont really know until I have it looked at. trying to avoid buying everything twice if I don't have to.
https://www.jegs.com/i/Chevrolet-Per...55719/10002/-1 just an idea
Old Oct 4, 2021 | 03:00 PM
427Hotrod's Avatar
427Hotrod
The original heads may have been "ported" and be in great shape as far as a valve job.....but I can guarantee you there is a LOT of power available with a decent set of good aftermarket heads matched with a good cam. OEM heads just aren't that great as compared to anything you can buy these days. A basic 383 shortblock or complete engine will make you happy with good heads and cam.
JIM
Old Oct 4, 2021 | 03:42 PM
onaqwst's Avatar
onaqwst
Some ideas...might have to just ditch the reuse what I have idea.... sell off the parts and hope to cover some expenses
https://www.jegs.com/i/ATK-Engines/0...model=CORVETTE
https://www.summitracing.com/parts/m...ette/year/1977
Might be easier to just pull/swap then try to rebuild/etc......
To Just bore the block??????
Old Oct 4, 2021 | 05:00 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
What is your compression ratio, you can throw alot of speed parts at it but if you have stock low compression pistons and heads your losing HP right there. I would just get the block bored, new high compression pistons and decent aluminum heads. A 355 will make great power with the right combo
Old Oct 4, 2021 | 05:06 PM
onaqwst's Avatar
onaqwst
No clue on compression ratio. I figure if I have to tear the engine down just to swap/change/bore the block, might be worth just a swap at this point.. If I had time/motivation to do it myself, maybe I would pull it, but would rather have it done by a shop.
Will see what they say when I swing by next week....
Old Oct 4, 2021 | 05:54 PM
ebbnflow's Avatar
ebbnflow
Default more brain fodder
Nowadays, virtually all crate motors have a one-piece rear main seal (GM changed from two-piece to one-piece '86-'87); their flexplates & flywheels have different bolt patterns and are not interchangeable. You'll need a New flexplate. New flexplate can be had for < $40. GM crate I suggest below has Forged Steel crankshaft and is the newer One-piece RMS design which has a smaller bolt circle than your Two-piece RMS motor has.
Be advised. All GM sbc crates are completely brand new top to bottom. And have the best warranty in the business with No Restriction on where you Must file any claim (sue) if you can't resolve a warranty issue.
Be advised. Crates from either ATK (aka Vege) and BPE have a warranty which Restricts user to file (sue) in Company's State of choice; ATK/Vege = Illinois while BPE = Nebraska. Suggest read the fine print and/or consult Your counselor Before writing the check; because, sadly, sometimes stuff happens.
The BPE motor referenced above has a New block but many (if not most) BPE crates use a remanufactured block which has been bored out to (or beyond) blocks' intended/practical limit.
ATK/Vege crates are similar; some have new blocks while some use a remanufactured block which has been bored out to (or beyond) blocks' intended/practical limit.
When it comes to cranks: Cast Steel is Not Forged Steel. Cast is Cast. Forged is Forged; and is more robust than Cast.
FWIW, GM sells a True 383" (the one you reference) with standard 4 inch bore & 3.800" stroke forged crank.
This $3600 motor: from GM
https://www.gmperformancemotor.com/parts/12691673.html
This roller motor will easily make 300-315 Gross SAE HP on an engine dyno with a good carb & distributor & headers
With a drop-in spring & retainer swap ($140),bigger roller cam swap ($250) it'll easily make ~ 425 Gross SAE HP on an engine dyno; and do it reliably.
Freshen your carb & dist, a new Vortec intake $175 ...DIY I'm seeing under $5K. Cam & spring swap rather easy.
four USA-made billet steel roller cams for sbc
https://www.summitracing.com/search/...rder=Ascending
think long & hard
