Not getting any fuel
Old Oct 16, 2021 | 03:48 PM
Theoriac's Avatar
Theoriac
1st Gear
Default Not getting any fuel
My 82, after setting for about a month, is not getting any fuel to the motor. I don/t know if it the fuel pump or regulator.
Old Oct 17, 2021 | 08:16 AM
Fly skids up!'s Avatar
Fly skids up!
The fuel pump supplies fuel to the throttle bodies. The regulator restricts fuel back to the tank. How do you know that you're not getting any fuel?
Old Oct 17, 2021 | 08:29 AM
fake's Avatar
fake
Try placing some gas in the tank for fuel gauges that year went bad often,
Old Oct 20, 2021 | 08:03 PM
Mrvettenick's Avatar
Mrvettenick
When you turn the key to the On position, does the pump run for 2 seconds? If it runs, then a fuel pressure test is necessary. Pressure should be 9-12 psi. If it doesn't run, then the pump is bad or the relay and/or fuse has blown.
To Not getting any fuel
