LT-1 camshaft in base 71 engine
Old Oct 22, 2021 | 12:06 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Default LT-1 camshaft in base 71 engine
I'm changing the camshaft in my base 71 350 with 270 bhp numbers matching all original engine.
Can I put the LT-1 camshaft in and hope for the same horsepower?
I have Performer intake and long tube headers on the car.
Or are there better camshafts on market to go with stock setup?
Old Oct 22, 2021 | 12:10 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Use the 262 Comp for automatic and the 268H for 4 speed......both cams will boost power about 40-50 hp over the stock 270hp cam......will run excellent with the 2101 Performer and long tubes.
The factory LT-1 cam is a solid lifter deal and you do not have studs and the guide plates necessary for this........
Jebby
Old Oct 22, 2021 | 12:11 PM
Primoz's Avatar
Primoz
Jebby
I can always count on you Jebby for some solid advice. The car is TH400 equipped.
Does this cam provide enough vacuum for power brakes?
Do you have the complete part number of the cam?
Primoz
Old Oct 22, 2021 | 12:24 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Primoz
You would do well to install this whole kit:
https://www.summitracing.com/parts/cca-k12-262-4
You should install at least roller tipped Comp Magnum rocker....and make sure you measure the pushrod with the quick checker.......buy only 1 piece pushrods from Trick Flow or Trend. A set of umbrella valve seals from Sealed Power is perferred too. You will need an adjustable length pushrod as well.
The 262 or 268H provide plenty of vacuum for brakes and lights/wipers.
https://www.summitracing.com/parts/man-42137
Jebby
Old Oct 22, 2021 | 12:27 PM
BLUE1972's Avatar
BLUE1972
Old Oct 22, 2021 | 12:28 PM
Primoz's Avatar
Primoz
I got recommended CompCams High Energy CL12-210-2 and avoid xtreme energy and go with high energy and magnum ones.
Recommendation came from very respectable builder.
The whole kit:
https://www.summitracing.com/parts/cca-k12-210-2
Old Oct 22, 2021 | 01:01 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The whole kit:
That is the 268H I mentioned above.......excellent choice but the 262 makes a little more torque down low and doesn't suffer from break in issues as it is small enough......stay away from the 274 or larger.
It will run well with the 268H and the th400.
Jebby
Old Oct 22, 2021 | 08:57 PM
lars's Avatar
lars
Primoz -
I see you're fact-checking me against Jebby... that's pretty funny... Do you know that Jebby and I work together and share info on a lot of this stuff? We both have similar backgrounds and do the same type of work. You can usually ask both of us the same question, and you'll get the same answer without either of us talking to the other... (but we usually do anyway).
Lars
Old Oct 22, 2021 | 11:00 PM
Primoz's Avatar
Primoz
Originally Posted by lars
Primoz -
Lars
No disrespect to you or Jebby, but I'm like that. I research and ask a ton of questions to make sure I don't get it wrong. Especially with this kind of jobs in which I don't have experience in.
Thanks to you and Jebby for all the help and advice! Greatly appreciated!
Old Oct 23, 2021 | 05:19 AM
Pale Roader's Avatar
Pale Roader
Jebby
I've noticed you usually recommend this one for stockish builds. Is that due to the stock head limitations? A few ov my friends have 275-280ish range cams in their 350's, and they work great. None are running stock, untouched heads though. I'm also assuming 4-speed, and no converter BS to deal with.
Old Oct 23, 2021 | 07:58 AM
ebbnflow's Avatar
ebbnflow
clique cabal
Old Oct 23, 2021 | 10:38 AM
REELAV8R's Avatar
REELAV8R
Look at the dyno profiles on the two cams provided by comp.
They are almost identical with the 262 slightly outperforming the 268 at the top of the rpm range. The 262 provides more vacuum if you want that. The dyno's are results from 9:25:1 CR. If you're lower than that ( you likely are) I would go with the 262 vs the 268 just due to better torque due to less duration and overlap. However the 268 does have better valve lift and more duration, a good choice for more CR if that's something you might be looking to do. I suspect if the cr was closer to 10:1 the 268 would outperform the 262 by a pretty good margin.
https://www.compcams.com/xe268h
https://www.compcams.com/xe262h
Old Oct 23, 2021 | 01:24 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
None taken…..good luck on your project!
Jebby
Old Oct 23, 2021 | 01:35 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yes….anymore cam than this is a diminishing return really unless the stockish heads are ported…..the heads have reached the limit of flow and more cam trades off very little power increase for a decrease in street manors, and they are soggy down low……but some like the “Fairgrounds Sound”…..I know I do…..I have an ancient 292H Magnum in my 406…with 10.5 to 1 compression….it makes a nice soundtrack but only makes 11 inches of vacuum…..IMHO, there is no better sounding cam for a small block, the 292. Just depends on what you want….
A 406 has no lack of torque so I put a “bottom of the page cam” in it…..but it runs and drives VERY nice….a lot of this has to do with the Dart wet flow heads….
Back to the 268H…..it is a solid old grind…..
Interesting on the 262…..
The 268H sounds a lot lot better….I can tell you that…..
I doubt highly you could tell the power of the two cams back to back….but for an auto, the 262 pulls a converter better….
Maybe I am biased by sound! Lol!!!
Jebby
Old Oct 24, 2021 | 06:15 AM
Primoz's Avatar
Primoz
Jebby
Do you have any part numbers for the 262 cam that you are talking about?
Also another thing.
If I wan't to go with roller cam does that provide any additional bonuses for me and my street/weekend style driving? Or is just an expensive option minding that I opearate on a budget?
Old Oct 24, 2021 | 09:41 AM
ebbnflow's Avatar
ebbnflow
No matter what your budget is; a roller cam-lifters is a good thing. Because flat tappet failures do happen and happen quite often during cam break-in / or soon thereafter. Those flat tappet Failures can be Very costly. Roller cam-lifters require virtually no break-in; nor do they require life-long diet of special oil and/or high-Zinc supplements (as do Most flat tappet cams).
Yes; roller cam-lifters are considerably more expensive (to purchase) than are flat tappet cam-lifters.
Are you risk-averse? Or, are you feeling lucky?
Pick your poison.
FWIW, if a project begins with a later sbc (later than C3 era); those motors either came OE w/ roller lifters or More readily accept less-expensive OE roller lifters.
For both environmental and political reasons, auto manufacturers universally adopted roller lifters decades ago; after recently REQUIRED catalytic converters were being ruined by the high-Zinc oils (which were typical for that era). That era is long-gone and so are Most of the high-Zinc oils.
Old Oct 24, 2021 | 10:40 AM
MelWff's Avatar
MelWff
Isn't another consideration in cam selection the differential gearing. The base 71 350 had 3.08 which I believe would be a poor choice for an LT1 cam.
To LT-1 camshaft in base 71 engine
Old Oct 24, 2021 | 11:14 AM
derekderek's Avatar
derekderek
The only correct usage for an LT1 cam is in an LT1 that is original. Better than L48 cam but still a 50 year old design with ramps too long forcing unnecessary overlap.
Old Dec 9, 2021 | 02:53 PM
Primoz's Avatar
Primoz
Just got the word that my heads are done!
2 valves were bent. Slightly.
My engine builder recommended this camshaft kit:
https://www.compcams.com/xtreme-ener...all-block.html
Anyone uses this cam?
Old Dec 9, 2021 | 03:48 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Too small IMHO…..I stick with my recommendation above.
Jebby
