TKO 600 starter
Old Oct 24, 2021 | 12:26 PM
joserpaq's Avatar
joserpaq
Default TKO 600 starter
Hello Guys
Any recommendation on a starter for stock L48 with newly added TKO600?
I have 168 tooth flywheel.
TIA
Old Oct 24, 2021 | 02:17 PM
ebbnflow's Avatar
ebbnflow
Amazon Amazon
Old Oct 24, 2021 | 03:50 PM
gkull's Avatar
gkull
I use a 4.5 HP gear reduction Power master from summit racing. It would really crank a smaller motor
Old Oct 24, 2021 | 04:56 PM
OldCarBum's Avatar
OldCarBum
As gull stated above, Power Master mini, high torque starters are hard to beat.
That’s what I’ll be running on my 496/TKO600 combination.
Old Oct 24, 2021 | 06:33 PM
gkull's Avatar
gkull
It's a dual size flex or flywheel and adjustable to move the starter motor in and out between the block and exhaust system
Mine has never needed a heat shield even with really hot headers
Old Oct 24, 2021 | 07:58 PM
Fly skids up!'s Avatar
Fly skids up!
Be aware that starter is a knock off of the Delco PG260 starter.
Old Oct 24, 2021 | 08:14 PM
ebbnflow's Avatar
ebbnflow
and a good one at that! I've run DB starters & alternators over the course of some ten years. I'll buy again if the need arises. Go ahead & spend 3 to 5 times if it makes ya feel better.
Old Oct 24, 2021 | 08:17 PM
joserpaq's Avatar
joserpaq
Good point guys. If that DB starter will work I’ll give it a try. I’ve spent way too much on this conversion already.
Old Oct 25, 2021 | 01:13 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
CVR 5323 is the only one I will use on anything.
Jebby
Old Oct 25, 2021 | 01:32 PM
nyciti's Avatar
nyciti
Power master here but I also run a Ford remote solenoid also, which I put on every Chevy I've ever owned. So cheap AZ or not I don't worry about heat soak or issues starting since I always run headers too.
Old Oct 25, 2021 | 05:29 PM
Fly skids up!
I'm feeling better already
Personally I wouldn't cheap out on a starter. But hey to each their own.
To the OP, a good strong starter will is beneficial if you want to bump up the timing.
Old Oct 25, 2021 | 08:54 PM
gkull's Avatar
gkull
? Is that a 168 tooth
Old Oct 25, 2021 | 10:14 PM
ebbnflow's Avatar
ebbnflow
the OP states his FW has 168T. Obviously, the DB piece has staggered mount bolt pattern; therefore is 168T.
It also has an "R" terminal which can be ignored if not needed. In this matter, I wouldn't have recommended other than 168T.
Old Oct 25, 2021 | 11:11 PM
gkull's Avatar
gkull
You don't see that on the link is why I ask.
Old Oct 25, 2021 | 11:39 PM
joserpaq's Avatar
joserpaq
Would this powermaster 9100 work for this application? $116 at wallmart with free shipping.
https://www.walmart.com/ip/Powermast...ctedSellerId=0
Old Oct 25, 2021 | 11:55 PM
ebbnflow's Avatar
ebbnflow
The DBE piece is an OE replacement starter. Yes it's very small, light and powerful but it IS an OE-type part.
AFAIK, that old common sense straight across OE bolt pattern = 153T versus staggered OE pattern = 168T has been SOP for most of sbc history; long time George.
Perhaps my stints as a counterman while I slogged thru college engineering, as well as a parts-gopher in my uncle Sam's Large junkyard while in HS helped ground me more than I realize?
Also, I was and am quite proficient with printed Hollander interchange manuals; own a few older volumes from when Sam died and yard was liquidated
Old Oct 26, 2021 | 12:31 AM
ebbnflow's Avatar
ebbnflow
depends if your block has several holes in one straight line. FWIW, the motor itself is a Hitachi-style design; perhaps manufacture as well.
However, I have never liked any chevy starter which has NO bearing support at Both Ends of shaft. That 9100 has no support beyond the gear. There are Many aftermarket brands with that drive design; not for me. Others will swear by them but I cannot recommend that design. YMMV.
To TKO 600 starter
Old Oct 26, 2021 | 12:02 PM
Fly skids up!
Don't be to quick to condemn Powermaster 9100 for not having the pinion supported on both ends. I needed to remove the mounting block from mine to remove a shim. The pinion is on 1 inch shaft being supported a 1 inch ID bearing in a aluminum block. I wish I would have taken a picture. It's a very beefy setup.
Old Oct 26, 2021 | 12:52 PM
ebbnflow's Avatar
ebbnflow
Off with his head !
Old Nov 4, 2021 | 11:54 PM
joserpaq's Avatar
joserpaq
I wound up installing a powermaster 9100 to work with TKO but I can't seem to get it lined up correctly and it has some grinding. The starter mounts on the straight across bolts versus staggered like stock starter. I already have transmission in so I can't check for clearence but it sounds like the starter gears are too far from flywheel with no shims installed. Seems to me that shimming would only move the starter gear further away from flywheel. Am I wrong? Can I shim one side of the stater to move gear closer?
