mate 350 engine to trans
Old Oct 25, 2021 | 12:55 PM
B77's Avatar
B77
Default mate 350 engine to trans
trans was in gear when motor was pulled without trans. after rebuild tried to mate engine with trans
I got engine and trans together within quarter inch. I pulled them together with the bellhousing bolts
now it seems to be on a bind and won't come out gear! motor is not running. could I have damaged
the spline? thanks Bob
Old Oct 25, 2021 | 01:07 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
No...you need to release the clutch disc a bit.....then it will slide right in......you have to move the fork a bit somehow, and wiggle it in at the same time.
Jebby
Old Oct 25, 2021 | 08:17 PM
B77's Avatar
B77
thanks Jebby I'll give it a try this week
To mate 350 engine to trans
