Quickjack
Old Oct 25, 2021 | 03:37 PM
Roentgen's Avatar
Roentgen
Default Quickjack
Hello All:
Anyone ever do the Auto to Tremec TKX 5spd swap with a Quickjack. I have a TKX 500 coming at the end of the month, and would like to make my life easier. Thinking my only other option here is Jackstands
Any opinions appreciated.
Old Oct 25, 2021 | 05:05 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I don't see why not. The new Quickjacks are 3" higher if you are looking to buy.
Old Oct 25, 2021 | 05:06 PM
Mooser's Avatar
Mooser
I didn't do any conversion but I did drop and remove a TH400 from my 72 using the 5000 quickjack. (OLD STYLE)
I did need to drop the trans right down onto a piece of cardboard on the floor in order for it to be slid out from under the car as there was just enough room and it couldn't be put onto a roller tray or anything. If I did it again I'd add a block (not stacking the 2 rubber ones) or a set of the SUB stands and get that extra few inches which would have made it slightly easier
M
Old Oct 25, 2021 | 05:27 PM
carriljc's Avatar
carriljc
I've dropped and reinstalled my tranny using ramps several times. It's doable but this sounds like a good reason to get a Quickjack
Old Oct 25, 2021 | 05:34 PM
onaqwst's Avatar
onaqwst
good reason to buy more tools.... i approve..
Old Oct 25, 2021 | 08:46 PM
cagotzmann's Avatar
cagotzmann
Originally Posted by Roentgen
Hello All:
Do your self a favor and purchase race ramps for this install. I have used the quickjack for the T56 Magnum but the quickjack gets in the way installing the crossmember. and moving the transmission in from the side of the car.
I used race ramps on all 4 wheels. This gives the same clearance under the car.
Old Oct 25, 2021 | 09:03 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
quick jack and removable crossmember....best tranny help out there. Then find a really good tranny jack that takes up little space. The scissors style aee the best but are jumpy unless you grease them liberallly
Old Oct 26, 2021 | 02:06 PM
CA_WxMan's Avatar
CA_WxMan
I use my Quickjacks all the time, but when it comes to trans work, I prefer to have the sides open.
I raise the car up with the Quickjack, then set it on cribbing and heavy jack stands so that I can pull the Quickjacks out of the way.
This lets me get under the car from the side, which is much easier that sliding in from the front/rear.
If you pull them out, have a couple buddies stand on them while you lower them.
When I'm ready to take the car down, I have someone stand on each jack while I raise them and set them on the lower locks. Then I slide them under and raise them up to lift the car off the stands.
It works pretty well, but we've done it a few times and have refined it a bit each time.
Old Oct 27, 2021 | 10:09 AM
Roentgen's Avatar
Roentgen
Tks for all the replies Guy's, I now have more than one solution
To Quickjack
