Timing Light
Old Oct 26, 2021 | 09:29 AM
jmgreer1's Avatar
jmgreer1
Default Timing Light
A quick look around and every advanced timing light I've looked at has a bunch of bad reviews. Can anyone recommend me a timing light that will give both timing and tach?
Old Oct 26, 2021 | 09:39 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have this one:
Amazon Amazon
It is reboxed as Actron or Innova as well....works great and has a metal inductive clamp....no more melt.
For MSD box or similar I have an ancient Craftsman strobe.......dial back style are inaccurate with ignition boxes.....
Others here use the $100 Innova fold up style and like those too.....
Amazon Amazon
Jebby
Old Oct 26, 2021 | 10:05 AM
Mr D.'s Avatar
Mr D.
I have a Snap On MT-1241 that has served me well for 33 Years.
Old Oct 26, 2021 | 10:09 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I like my digital Innova.
Old Oct 26, 2021 | 12:01 PM
Catfish4818's Avatar
Catfish4818
I have (and love) this Innova 3568 -
Old Oct 26, 2021 | 01:00 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Another vote for the Innova.
JIM
Old Oct 26, 2021 | 02:07 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Lol, no bad reviews here!
Old Oct 26, 2021 | 04:13 PM
C3 Stroker's Avatar
C3 Stroker
Another vote for Innova. I have the model #5568.
Amazon Amazon
Old Oct 26, 2021 | 04:35 PM
Bikespace's Avatar
Bikespace
Innova 5568. Love it!
Old Oct 26, 2021 | 06:15 PM
Mooser's Avatar
Mooser
5568 without the MSD box
regular old strobe for the box (check for craigslist or garage sales for an old craftsman or something, most are just collecting dust now and can be had cheap)
M
Old Oct 26, 2021 | 07:09 PM
kansas123's Avatar
kansas123
Also do not work with petronix??? Thanks
Think I answered my own question reviewing another post. MSD box is different than running a points distributor converted with Petronix I think?
Old Oct 26, 2021 | 09:41 PM
jmgreer1's Avatar
jmgreer1
Thanks for the replies. I ordered the innova.
Old Nov 2, 2021 | 11:03 AM
jmgreer1's Avatar
jmgreer1
I purchased the innova 3568. As I understand how the light works, you change the degrees of timing on the gun until the timing mark lines up with the 0* mark on the timing tab to find the current set timing. To set the time you want, change the gun to the desired time and rotate the distributor until the mark lines back up on the timing tab 0*. Is this correct?
I’m finally getting around to working on the car after taking care of a few things and having Lars do the rebuild. It fired right up, but the timing is funny. The only way I can see the timing mark is if the gun is set to 90* and then the mark is lining up at 14* before TDC.
Have I set the car up on the wrong TDC (exhaust vs compression… would it even run on that setting)? I haven’t verified that the timing mark is correct. What guidance can you guys give me here?
Old Nov 2, 2021 | 11:09 AM
Eric P's Avatar
Eric P
Sounds like your on cylinder 3 instead of 1 for the 90 degrees reading plus 14 , you are correct in operation but RPM must be set for the intended purpose such as base is low rpm and total timing is over 2500 or more rpm
Old Nov 2, 2021 | 11:12 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You need to verify TDC #1 for the timing mark before you go any further........50% of old balancers out there have the outer shell spun on the hub causing the mark to be way off........if the mark is off, replace the balancer......
If it started and it is smooth.....you are probably ok....but double check your firing order and rotor position at TDC #1.
Jebby
Old Nov 2, 2021 | 05:53 PM
jmgreer1's Avatar
jmgreer1
After taking the advice, my plugs were out of order and the sensor was one wire #3…
Now I can check actual timing. At idle and with vacuum disconnected, initial timing is set at 12*. Maximum mechanical advance is in by 2200 rpm but it’s only about 22*. I’ve changed the springs out for lighter (gold). What do I do next to bring in more timing?
Old Nov 2, 2021 | 06:00 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Just set your timing to 36* at 3000 rpm and don't worry what the initial is - its just a number.
To Timing Light
Old Nov 2, 2021 | 06:26 PM
Eric P's Avatar
Eric P
Raise idle speed until it quits advancing , 2200 rpm is not enough
Old Nov 2, 2021 | 06:54 PM
Bikespace's Avatar
Bikespace
Email Lars for his instructions, and follow them. If you have 10 total degrees of mechanical advance, and it's all in at 2200, you actually need heavier springs. You can mix and match to get them to be all-in at 2800-3000 RPM.
Is there something limiting the mechanical advance inside the distributor? Is it a late 70s L82 HEI distributor?
Old Nov 5, 2021 | 04:50 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
the weights and amount they swing sounds like only 10 deg of travel.
there is are bushings that limit travel.
or the weights are already moved at idle
from weak springs.
basically
12-14 at idle plus 20 from weights travel limit
gives 32-34 all in
