68 Air Conditioning Plenum Valve Removal
Old Oct 31, 2021 | 11:00 AM
76yellow's Avatar
76yellow
Default 68 Air Conditioning Plenum Valve Removal
I've got the wiper door removed and 2 screws removed but I can't figure out how it comes out ! The factory had to put it in but how ??????
Old Nov 1, 2021 | 09:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pics would help. What are you calling a "plenum valve"?
Old Nov 1, 2021 | 04:32 PM
76yellow's Avatar
76yellow
Pretty hard to get a picture because of where it is ! The AIM manual calls it a "Air Conditioning-Plenum Valve" It's located Inside of the wiper door and under the fender on the passenger side. Its the vacuum actuator thats attached to a door that I want to remove. There just isn't any access to from any direction !
Old Nov 1, 2021 | 09:28 PM
thatcorvetteguy's Avatar
thatcorvetteguy
Turn it sideways then fiddle to get it out, The biggest problem is that a new door is unavailable. 69 and up is different, no matter what the supplier will tell you. The left pic is the 69 up the right is 68 only.
To 68 Air Conditioning Plenum Valve Removal
