Interested in big Block for '82
Old Nov 5, 2021 | 09:37 AM
1860army's Avatar
1860army
Another thing to consider is that your 82 hood has the breather tunnel on the underside limiting your total engine height - will prob have to be replaced with L88 replica or high-rise version.
A good dremel will take care of that tunnel... Spray Arid Extra dry on the hood, use globs of play dough on the air cleaner, one in the middle the rest around the edge when you lower the hood the play dough will leave marks. You will see its a little off center, I cut a cardboard circle a little bigger than the air cleaner and traced around it on the hood then cut it out. It actually works out good if you take the flapper off the hood the air cleaner is siting in the path of the cooler air coming in...
​​​​​​​60
Old Nov 7, 2021 | 04:46 PM
zdave83's Avatar
zdave83
Originally Posted by L-46man
Dave, You are making assumptions that your C-3 may not support. To whit; Knowing the C3 was designed for big block engines....
Bad assumption!
Early models up to 1979 were designed for prodigious torque...NOT the one you currently own!
1. You have the aluminum Dana 36 rear end....good chance it will explode!
2. In 1980 Chevy reduced the thickness of the frame by 20% BECAUSE THEY DIDN'T MAKE BIG BLOCK CORVETTES ANYMORE!
3. Weight savings was the key then, not torque nor torsional resistance.
You probably can change the rear end to a '79 or before by grinding welding and replacing the differential and carrier.
However cracked fiberglass may be in your future.
Just know this going in!
Cheers Unkahal
I did not know about the change in frame thickness ! Do you know if there are published frame rigidity tests comparing before/after ?
I factored in changes to the rear end diff and other components. Also considered some info after researching torque tubes. The best answer is probably a good cage.
Definitely want to avoid cracked fiberglass !
Still interested in hearing from people who have accomplished this change.
Old Nov 8, 2021 | 09:58 AM
L-46man's Avatar
L-46man
To keep adding to this thread...not being a nay-sayer, just a mechanical engineer!
Springs will have to be up-rated all the way around.
Bilstein yellows are a must.
(I'm definitely not a coil-over kind of guy..theres' no suspension travel to begin with!)
Attend to Cooling,.. your radiator is a small block radiator.
One big PLUS about the 80-82 'shovel-nose' body is 50% more cooling air into the radiator!
I'm not a lover of the 12 point half shaft yokes....again down-rated.
Obviously this can be done...just be aware of the pit falls.
As far as I've been able to research, I have never actually seen torsion and beaming rigidity tests, computer or otherwise on the lightened frame. Assume 20% less or more, than a 79.
Good luck and SUBSCRIBED!
Unkahal
Old Nov 8, 2021 | 02:41 PM
68/70Vette's Avatar
68/70Vette
I'd recommend the ZZ502 from GM Performance Parts. It comes with aluminum heads. With an aluminum intake, aluminum water pump, the engine weight is, I believe, in the range of the iron small blocks in the C3's. 502 hp. This could stress the Dana, but the rest of the drive train should survive if you don't aggressively drag race. The L88 optioned C3's were sold with the same drive train as the other C3's and these engines were rated at 550 hp flywheel hp. They were well suited for road racing with the standard drivetrain. As for hood clearance, a standard BB/LT1 hood should work. You will need a custom "long" hood. L88 "long" hoods are readily available and this will alleviate the hood clearance problem. You probably can use the L88 cold air function as a bonus. The 502's have the block deck height as the traditional BB's, so valve cover clearance with the PB vacuum canister shouldn't be a problem.
I've never read that the factory L88 cars had anything much different in the drivetrain than the other C3's. A "long" C3 hood is for C3's that didn't have the early C3 windshield wiper doors. Also, BB's in C3's really need, IMO, aluminum heads. The 650 pound weights of the all iron BB's is just too much weight for a C3. The aluminum heads weigh 42 pounds each. Mine do. This means the iron heads must be north of 100 pounds each. Gross.
Old Nov 8, 2021 | 04:44 PM
pspicci's Avatar
pspicci
Originally Posted by zdave83
Yeah ...... nothing against the other hoods but was hoping there'd be a way to keep the original. Don't know if there's a modern low profile manifold setup that would help.
I'd be interested in hearing from anyone who's been able to get a big block under the '82s stock hood. I assume a tall-deck is out of the question.
The Edelbrock Torker II is supposed to fit under a stock Big Block hood. As far as how good it is you need to do your research on it. some people don't like them and others have had good success with them. Either way they are probably at least better than a stock low rise BBC manifold.
Old Nov 8, 2021 | 05:06 PM
L-46man's Avatar
L-46man
The earlier 80-81 hoods did not have the big ram air plenum underneath...maybe 2" more inches.
Unk
Old Nov 9, 2021 | 11:52 AM
L-46man's Avatar
L-46man
Dear Dave,,,here's a 'giftie' for your project.
Best of luck Unkahal
https://lasvegas.craigslist.org/pts/...394056786.html
Old Nov 9, 2021 | 02:16 PM
zdave83's Avatar
zdave83
Wow that thing's big !
Old Nov 9, 2021 | 02:19 PM
L-46man's Avatar
L-46man
Default big block
This allows you to cook a 22 lbs turkey on top of your aircleaner! Its a BB, so might as well USE all that underhood heat!
Unk
Old Nov 9, 2021 | 02:56 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Bad assumption!
Cheers Unkahal
#2: I've heard about the reduced frame wall thickness many times, but I've never seen any actual official documentation regarding it. Can you link something regarding this item?
Old Nov 9, 2021 | 03:05 PM
L-46man's Avatar
L-46man
I got these dimensions from TOM FALCONER. NCRS 'czar' for all Europe. Based (formerly) in the UK...DBA Claremont Corvettes.
The dimensions are in EVERY one of his books.
These dimensions have been VERIFIED in this forum BY ACTUAL MEASUREMENT OF FRAME WEB THICKNESSES.
(It's a FACT, jack!)
Cheers Unkahal
Old Nov 10, 2021 | 11:34 PM
Eric P's Avatar
Eric P
Do you have any proof at all that the thinner frame will buckle under a big block ? One smidgen of proof ? Any documents that support your conclusion ?
Old Nov 11, 2021 | 06:05 AM
  #33
derekderek's Avatar
derekderek
you don't break things with a big pretty engine. you break things by abusing them. if you want a big block because you want one, ok. a gen 6 454 for 300 bucks will do for starters. if you want to try to get into the 12's or better, a sturdier drivetrain is a must. you can break stuff with a 165 hp 75 engine if you try...
Old Nov 11, 2021 | 10:27 AM
  #34
L-46man's Avatar
L-46man
Originally Posted by eric p
do you have any proof at all that the thinner frame will buckle under a big block ? One smidgen of proof ? Any documents that support your conclusion ?
i did not say it will buckle...nowhere, did i say that!
Frames twist. This is called torsional rigidity. When you remove 20% of the metal, torsional rigidity goes down....simple fact of life.
unk
Old Nov 11, 2021 | 10:47 AM
  #35
djquik1's Avatar
djquik1
I would go LS over a big block but either way you have to address the rear axle, But a big block would be cool. There is a guy on the other forum doing this swap on a 1981 and swapping to a manual. He is doing a 502 if I am not mistaken. Either way subscribed, I plan on going LS or Big Block eventually on mine after I get it going with my small block.
