Vacuum pressure
Old Nov 10, 2021 | 03:01 PM
PennyJack's Avatar
PennyJack
Default Vacuum pressure
I have replaced all valves and motor the wiper door opens and closes only if I change the hoses bake and forth on regulater when all hoses are in correct positions it will not switch back and forth to open and close
Old Nov 10, 2021 | 07:35 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
can you post the year and try and explain the problem a bit better
Old Nov 11, 2021 | 10:56 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
If it works in the 'incorrect' position, then don't connect the hoses in the 'correct' position.
Old Nov 11, 2021 | 11:23 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Do your headlights operate as they should?
Can you post pics of what component you are moving the hoses on to test operation?
Sounds to me like your wiper door actuator isn't operating correctly or maybe not getting the proper signal from upstream. There is a "piston" inside the cylinder where the hoses connect and that isn't moving to open and close the ports as needed. You might try a couple drops of oil down the two end ports to ensure it slides smoothly.
Have you also inspected the couple of switches on the dash cluster? There are the two "emergency/manual" pull down switches (one headlights, one wipers) below the steering column and a wiper electrical / vacuum switch located on the back of the speedometer. (The counterpart to the headlight electrical / vacuum switch on the headlight pull ****.)
To Vacuum pressure
