Heat Riser
Old Nov 5, 2021 | 04:46 PM
mbp's Avatar
mbp
Default Heat Riser
Hello. I would like to take the heat riser valve out of my 69. I Believe that it is basically a matter of taking the nuts that attach it between the manifold and exhaust pipe. My question is if it can be done with out having to put heat to those nuts and just frequent soaking of penetrating oil. Not sure how or when they were installed. It would be nice if they used some hi temp never seize. Just wondered if anyone has been successful with out having to heat them. I don't want to snap a stud or two or three. Thanks and take care.
Old Nov 5, 2021 | 05:13 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes I've gotten them apart many times. I have also stripped and snapped off studs.
How rusty are they? did the last guy use Anti-seize? Do they have the brass nuts on them?
All you can do is try. there are no guarantees.
Soak em for a couple days, reweting them often. then give it a go. replacement studs are cheap. Drilling out the old stud. Not so much fun.
Old Nov 5, 2021 | 05:19 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
never know until,,,,
work it out and in if you get a turn going.
take time.
good luck
Old Nov 5, 2021 | 09:57 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
If they're the standard, long length studs, run a thread chaser the open length of the studs. That will at least allow the nut to free-turn once it hits that section. I'd still try heating the nuts with a propane torch and allowing to cool, cycling at least 2 or 3 times to break any corrosion bonding between the two parts. Liberally apply a penetrating lubricant (not WD-40) to both sides of the nut prior to and after each of the heating cycles. PB Blaster is a pretty good commercial product for that. Then lastly, lube the open stud lengths prior to unscrewing the nuts. Hopefully all will let loose easily.
Old Nov 6, 2021 | 01:26 PM
speedreed8's Avatar
speedreed8
Removing the heat riser will probably require a spacer which most vendors sell or gut the oem one and weld up the shaft holes and reinstall it.
Old Nov 7, 2021 | 10:47 AM
mbp's Avatar
mbp
Want to thank those who answered. With lots of PB Blaster and a bit of time the studs came out fairly easily. Perhaps never-seize had been used? Anyhow no broken studs or drill work needed. Nice not to have one job ending up to be two or more jobs. Take care.
Old Nov 8, 2021 | 12:12 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Use the brass nuts on the new one.......
Jebby
Old Nov 8, 2021 | 01:11 PM
mbp's Avatar
mbp
Hi. The brass ones are preferable over all metal locking?
Old Nov 8, 2021 | 10:01 PM
barkingrats
There may be other reasons, but i use brass because it won't rust to the steel studs plus it's softer than the steel so will strip out rather than snapping the stud off.
Old Nov 8, 2021 | 10:19 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
That is exactly right…..been using them for over 30 years….they stay tight too…..
Jebby
To Heat Riser
