Roller Cam 350 Problem
The engine only had maybe 30mins of starting and running up and down my 250’ driveway as the car is not ready for the road, but I couldn’t get it to accelerate without backfiring and coughing and spluttering. While trying to troubleshoot this problem, I happened to take off the rocker covers and discovered that many of the pushrods were not pumping oil to the rockers, so I decided to put in new lifters as I figured they were not flowing oil like they should. I did have trouble priming the engine when I first assembled it, and it took something like 20mins of priming with a drill and old dizzy to get oil out of all the arms, and even then they didn’t seem to flow much. The engine has 50+ PSI of oil pressure at idle and I’m sure there are no oil delivery issues. When I removed the old lifters I found that at least two cam lobes had some pitting starting to develop on the leading edge of the lobes, so I decided to replace the cam. The cam Comp suggested was really too aggressive for the engine anyway, so I figured a milder cam would be a better choice. I ordered a GM ZZ4 cam which is machined from billet steel rather than the Comp’s cast core, and I got a set of GM USA made LS7 lifters which are the OEM replacement for the roller small blocks.
I’m still working to fix the backfire and stumble when trying to accelerate (that’s a whole other problem), but I’m intermittently getting a chirping/squeaking noise from the engine which I believe is coming from one or more roller lifters. It sounds a lot like a a pulley, but it’s there even with the belts removed and it seems to be coming from inside the engine. It’s happened a couple of times after a short accelerate and then the engine squeaks until it’s shut off. After restarting the sound is gone. I’m assuming one of the lifters is playing up but I don’t know why. I’m a little bit concerned that the valve springs may not be strong enough They have a seat pressure of 100lb and an open pressure of about 260lb with my cam. Do you think that could cause problems with the lifters even thought they engine is only being revved to maybe 3500rpm?
A cam that is used for a retro roller lifter setup may have a different basecircle than the factory style........
DO NOT run this engine anymore until you verify the situation......
Backfire and stumble may be the POS accel pump in the Edelbrock carb......replace with a viton piece.
Jebby
I follow what AFR says about H-roller spring weight. They from the factory install 140# seat springs for sub 235 degree cams limited to about 6000 rpm SBC Then up around 150# for heavier valve train like BBC or higher rpm SBC.
BeeHive springs run @ 20-25 pounds less and still have the ability to maintain valve control. So your 100# wasn't a good choice with heavy H-roller lifts. You could have very low rpm valve float.
When people ask me to come and look at a rough running new build. You have three areas. Electrical, mechanical, and fuel. Verify plug wires order, is the dizzy set with the rotor and damper about 15 degrees past the #1 cap pole and balancer on zero? Do you have the correct lash settings. Too tight and the valves never fully close and the motor will have back fire problems, Do you have vacuum leaks? Are you running over 5 psi to the carb causing flooding problems, EDl carbs are wonderful if you understand them, but you only want less than 5 psi.
When you first time fire your car you should already have the timing light on it to verify the timing.
As far as the backfiring, I have done quite a bit of work to try to solve it without much luck. Initial timing with no vacuum advance is set to 12deg BTDC and I have the springs and stop in the dizzy setup for mechanical advance of 24deg all in by about 3000 RPM. I've tried both ported and manifold vaccum for the advance canister but it doesn't make much difference. I've adjusted float levels, changed step-up springs and put a new accelerator pump in the carb but that didn't help either. The plugs are getting a lot of carbon build-up so it's running too rich even though I've carefully set the idle mixtures for the fastest idle then backed them off slightly leaner. I'm thinking of changing the carb to a Holley 600 or 650, as the 750 is probably too big and the Edelbrock carb is driving me crazy. But I suspect that the misfire/backfire could also be a problem with the distributor as I got it used and don't know for sure that it's good. The engine dies severely when accelerating, almost like hitting a rev limiter, however it only does it under load not revving when stationary. I've ordered a new tach drive dizzy so when that arrives I'll find out for sure I guess
I remembered that when I installed the new lifters, a couple of them didn't feel super smooth when I put them in the bores, almost like a bit of a burr catching as they went in. I probably should have looked closer at that at the time, but maybe that's got something to do with the issue?
You could use a beehive spring like 26995 and install it at either 1.750 or 1.700 and have lifter control. Above you were looking at things wrong. It's a combination of factors. High spring weights combined with high ratio rocker arms and too thin of oil, low oil pressure causes H lifter to compress the inner piston. Your typical H-roller cam doesn't ever have lobe ramps so steep than it can compress the internal piston especially with sub 140 pound pound springs.
you adjust the oil pressure with oil weight. like if you have 20 psi at idle with 5W30 oil going to 10w30 might make it 25 hot or even going to 10w40 or 15w40 You need oil pressure to keep from bleeding down h-rollers. Keep the wheels oiled
Yesterday I pulled the intake and removed the lifters and everything looks perfect. The wheels on the lifters look brand new and the cam lobes have normal looking shiny lines developing where the rollers track on them. Based on that, I don't think the squeaking I heard was the lifters at all, but I don't know what it was. Glad I checked the cam and lifters for my own piece of mind though.
Something I did notice was that it looks like the backfiring is coming from cylinder 3, as there is a lot of dry carbon in the intake port on that one cylinder. The others are much cleaner, but do have some oil residue, which I think is because the PCV I was running seems to be flowing too much air and sucking a lot of oil. I'll just use a breather for now while I get the engine running right. I have done a compression test and all cylinders are around 190psi. I have a feeling that I have an ignition problem with cylinder 3.
Jan 18, 2018 · Valve Spring Style: Beehive (LS7 specific) Valve Spring Color: Natural: Valve Spring Seat Pressure: 100 lbs. @ 1.960 in. installed height: Valve Spring Open Pressure: 310 lbs. @ 1.370 in. open height: Valve Angle: 12 Degrees: Intake Valve Material: Titanium, hollow stem (chrome nitride PVD coated) Intake Valve Dia. 2.205 in. Intake Valve Weight: 77 grams: Exhaust Valve Material stainless steel sodium filled 74 grams.
I just looked up my Manley proflow light weight valves and thy are 134 grams I and 126 grams exhaust. So Big people like AFR through lots of testing use exactly what I posted above for spring pressures. I also stated that BeeHive springs use 20-25# less spring pressure and can still control the valves. You are not going to get away with 100 and less pounds unless you have a very low performance motor.
