Almost Burnt Down
Old Nov 24, 2021 | 11:01 PM
c.martin's Avatar
c.martin
Default Almost Burnt Down
The battery on my 77 died and i went to jump it when a cloud of smoke came pouring out of my hood and there’s a couple wires that are melted can anyone help me out on how to fix this.
Old Nov 24, 2021 | 11:26 PM
bmotojoe's Avatar
bmotojoe
Some photos of the area would help...
Early or late build 77?
Old Nov 24, 2021 | 11:36 PM
c.martin's Avatar
c.martin
i’m not positive on if it’s a late or early model but here’s some pic
tures
Old Nov 24, 2021 | 11:54 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and Welcome!
You might have connected the jumper cables backwards and burnt up the fusible links down by the starter.
Old Nov 24, 2021 | 11:59 PM
bmotojoe's Avatar
bmotojoe
Is it possible to get a photo of this area on your car, Starter...
I'm looking for any signs of burnt fusible links.
The wires just after those 2 white plastic capsules are the fuse link wires.
A early build there should be 1, a late build there will be 2 like my photo shows.
From your first photo it almost looks like a repair was made to the large RED wire bypassing that 4 wire connector.
Old Nov 25, 2021 | 12:10 AM
bmotojoe's Avatar
bmotojoe
The more I look at your first photo I'm 99% sure it is a late build 77 with A/C
Old Nov 25, 2021 | 12:12 AM
bmotojoe's Avatar
bmotojoe
Were the jumper cables hooked up wrong?
You wouldn't be the first if they were...
Old Nov 25, 2021 | 10:16 AM
augiedoggy's Avatar
augiedoggy
The damaged wire doesnt look stock to me? is it possible its an added wire running from the starter to the alternator that got chaffed against a screw or mounting bracket and arched out?
Old Nov 25, 2021 | 10:47 AM
c.martin's Avatar
c.martin
It does have an ac
Old Nov 25, 2021 | 10:48 AM
c.martin's Avatar
c.martin
I don’t believe so but I might be wrong.
Old Nov 25, 2021 | 10:53 AM
c.martin's Avatar
c.martin
Does this help?
Old Nov 25, 2021 | 11:00 AM
ebbnflow's Avatar
ebbnflow
Lectric Limited wiring harness(es)
https://www.lectriclimited.com/vehic...ke/21/model/65
Old Nov 25, 2021 | 11:05 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by ebbnflow
I have a painless wiring harness I used on my car but I installed an inline fuse close to the starter on the power wire in question here to prevent this.
Old Nov 25, 2021 | 11:06 AM
c.martin's Avatar
c.martin
I had someone take a look at it and they had a new distributor installed. They may have installed a new one.
Old Nov 25, 2021 | 11:23 AM
chuckwp's Avatar
chuckwp
Could have been worse.
Old Nov 25, 2021 | 11:26 AM
c.martin's Avatar
c.martin
That’s terrible 😂
Old Nov 25, 2021 | 12:24 PM
derekderek's Avatar
derekderek
any chance the jumpers were hooked up backwards?
To Almost Burnt Down
Old Nov 25, 2021 | 02:07 PM
bmotojoe's Avatar
bmotojoe
You have a mess there that could have been much worse!
I see so many things wrong already I would not try repairing any of that engine or starter wiring harness...
Sorry, that's my opinion...
I see NO fusible links at starter solenoid battery lug or dead short protection at all!
I think there is another wire that was also removed or bypassed around that 4 wire connector in 1st photo and someone ran a single new wire to solenoid battery lug.
​​​​​​If you need help with selecting the correct engine harness, and starter harness WITH A/C I can help in selecting the correct harnesses you need.
I believe your car is a late build 1977 with A/C but needs to be confirmed.
Old Nov 25, 2021 | 04:34 PM
c.martin's Avatar
c.martin
I don’t think they were I started to panic when I saw all the smoke though so possibly
Old Nov 25, 2021 | 04:36 PM
c.martin's Avatar
c.martin
I was looking to replace it anyway so that would be great and it does have A/C
