Tilt/telescoping
Old Nov 27, 2021 | 10:17 AM
LtaPilot's Avatar
LtaPilot
Default Tilt/telescoping
On my 72 with tilt/telescoping column, the key will not go to the accessory side of the switch. What can be the problem?
Old Nov 27, 2021 | 10:56 AM
71 Green 454's Avatar
71 Green 454
Are you pushing the key/ignition switch in before turning the key counterclockwise?
Old Nov 27, 2021 | 11:47 AM
Eliredandblack's Avatar
Eliredandblack
Is the steering wheel “Free” and not locked by the anti theft pin inside the steering column?a My 2001 Camaro on occasion will not allow the key to be turned “to start” position, if the steering wheel is locked with some pressure. I simply turn the wheel an inch or so to relieve the pressure (from the steer wheel lock” and then I am able to turn the key in the ignition to start position.
Old Nov 27, 2021 | 04:08 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
You may need an adjustment of the ignition switch on the lower part of the column.
__________________
Greg
To Tilt/telescoping
