PG260 Starter Users Question
Old Dec 8, 2021 | 10:08 AM
stingr69's Avatar
stingr69
Default PG260 Starter Users Question
Any of you PG260 GM permanent magnet gear reduction starter users ever find a starter brace to fit? I tried one of these starters for the first time and it works great but my old 10MT brace will not reach the lug on the much smaller PG260 mini starter. After looking around for one and finding nothing I thought I would ask what you all are using there?
Old Dec 8, 2021 | 10:21 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Unnecessary as it doesn't weigh but a third of the stock unit......the brace was due to the 20+ pounds hanging off the forward attachment, which created cracked noses. The factory applications for this starter (which were C/K and S trucks) didn't have a brace that I remember......I do remember that they were very troublesome without the shouldered knurled bolts......
Jebby
Old Dec 8, 2021 | 10:28 AM
stingr69's Avatar
stingr69
Jebby
Perfect. No brace it is.
I actually have (8) spares of the specific GM PG260 long starter bolts. Rock Auto sent me way too many -LOL.
Thanks!
Old Dec 9, 2021 | 07:16 AM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Whats the delco # for that starter and bolts in the rock auto catalog? Use with any flywheel?
Old Dec 9, 2021 | 07:22 AM
ebbnflow's Avatar
ebbnflow
Default correct bolts, No bracket
As said, correct bolts are paramount ... all Blocks do Not have same threads ... all Bolts do Not have same threads. Before mounting PGxxx starter, suggest dry-fit any new bolt to verify correct thread match.
Also suggest referencing all Pics and part numbers in this two-page pdf Remy tech sheet to assist verifying your bolts exhibit correct attributes (taper, knurl, thread pitch etc).
https://autoprollc.com/wp-content/up...eb2016_web.pdf
FWIW, I too have not seen an OE commutator-end support bracket used w/ light PMGR starters. If starter properly mounted w/ correct bolts; Not at all necessary.
FYI: Some come w/ Steel planetary ring gear (internal gear reduction) while others are Delrin /plastic. Either are good, but replacement steel are available.
Congrats on your choice ....Properly mounted, me thinks you will like PG260 starter.
Old Dec 9, 2021 | 08:17 AM
stingr69's Avatar
stingr69
The Remy document linked above shows the 4 basic part numbers for the starters. 2 are for "points ignition" solenoids and the other 2 are for "HEI" type solenoids. Diagonal bolt pattern are used with large 168 tooth flywheels and bolt patterns in-line are for small 153 tooth flywheels. The bolts are different than our original production parts and they are critical here so make sure you get those. These are brand new Remy starters, not rebuilt. VERY NICE.
Old Dec 9, 2021 | 08:35 AM
ebbnflow's Avatar
ebbnflow
check this Remy sheet from above whenever installing a PG aka PMGR type starter
if your OE (10MT) starter has a staggered bolt pattern; it's 168T ...
if your OE (10MT) starter has a Straight-across bolt pattern; it's 153T
Old Dec 9, 2021 | 04:00 PM
0311 jarhead
What I need is a starter and bolts for a GM crate engine that didnt come with a starter and bolts. On top of that I'm using an orig points/tach drive disto that has been converted to electronic. My flywheel is a McCloud 153 tooth for a one piece rear seal. Ive seen several mini starters from different companys that they say will work with any flywheel.
So my original question is what are the part #'s for a PG260 you used and bolts in the rock auto list?
Old Dec 9, 2021 | 04:16 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I use the CVR 5323….best damn starter you can buy IMHO….
https://www.summitracing.com/parts/c...+5ba262769f0d8
I don’t know of a GM permanent magnet starter for 153 flywheel…..the trucks were all 168 tooth.
Jebby
Old Dec 9, 2021 | 05:31 PM
stingr69's Avatar
stingr69
You need:
(1) 96207 Starter
(1) 12338064 Long Bolt
(1) 14037733 Short Bolt
I'm sure the CVR starter is a nice piece but it is double what the PG260 and bolts will cost you.
Old Dec 9, 2021 | 09:23 PM
ebbnflow's Avatar
ebbnflow
Jebby
BUICK ROADMASTER 1995-1996 CADILLAC FLEETWOOD 1996 CHEVROLET CAMARO 1995-1997 CHEVROLET CAPRICE 1996 CHEVROLET IMPALA 1996 PONTIAC FIREBIRD 1995-1997
Perhaps consider firing your source while putting your trust elsewhere..
Old Dec 9, 2021 | 09:27 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Ah….pass cars had a 153…..It’s all coming back to me…..
Like I said…. As far as I know….I get it wrong too.
Jebby
Old Dec 9, 2021 | 09:31 PM
ebbnflow's Avatar
ebbnflow
I fixed that for ya ... what else can I get for ya
Old Dec 10, 2021 | 08:44 AM
0311 jarhead
You need:
(1) 96207 Starter
Thanks, I appreciate that
Old Dec 11, 2021 | 01:59 PM
stingr69's Avatar
stingr69
Just an update - GM discontinued the special short bolt for this in-line style starter so if you have the small 153 tooth flywheel it will be a problem for you to complete this swap. Plenty of long bolts though for the larger 168 tooth flywheel applications.
Old Dec 11, 2021 | 02:04 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
That’s crazy….I looked and Dorman doesn’t do them either….
Jebby
Old Dec 11, 2021 | 02:22 PM
0311 jarhead
I need a short one for my setup, if anyone can lead me to one I'd appreciate it.
To PG260 Starter Users Question
Old Dec 11, 2021 | 02:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Any Camaros or Caprice/Roadmasters at your local salvage yard? Stuff is getting old but you never know.....
Jebby
Old Dec 11, 2021 | 03:49 PM
stingr69's Avatar
stingr69
Look for an LT and maybe get lucky. Watch out for the metric threaded ones. Your block is 3/8-16
Old Dec 11, 2021 | 07:16 PM
ebbnflow's Avatar
ebbnflow
short-long bolts here
https://www.dbelectrical.com/product...r-starter.html
disregard the included gasket; it's for a marine app. Read the page's bolt thread description.
Again, Never torque down a bolt without first verifying it correctly fits the female thread.
