72 LT1 thumping sound
Old Dec 10, 2021 | 10:10 PM
ray3222's Avatar
ray3222
Default 72 LT1 thumping sound
1972 dies on acceleration with thumping sound from engine. It idles & revs normal. Upon acceleration it loses power with loud thumping sound from engine & dies. Fuel pump & fuel filters & air filter & plugs ok.
Any ideas?
Old Dec 10, 2021 | 10:33 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Because it idles and revs normally, it sounds like a transmission/clutch issue since it only happens under motion. Is it a manual or automatic; stock or aftermarket? Has there been any change recently from before the sound began?
Old Dec 11, 2021 | 09:41 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
So it will not move under its own power at all?
Need a lot more info and detail......
Jebby
Old Dec 11, 2021 | 12:18 PM
diehrd's Avatar
diehrd
Any ideas?
Engines do not thump , They tick and knock.
Old Dec 11, 2021 | 12:32 PM
Mrvettenick's Avatar
Mrvettenick
If it's an original LT1, then it has to be a MT trans. That being said, what happens if you step on the clutch when it starts acting up? Does it get better?
To 72 LT1 thumping sound
