There's not a Chevy mechanic in the world, being paid flat rate, who doesn't put a 1/2" drive impact on the manifold bolts and just zips them out in any convenient sequence. It makes no difference - the manifold will not warp. I've done several hundred in my lifetime, and never had a warped manifold. Just pop the bolts out, no problem.
There's not a Chevy mechanic in the world, being paid flat rate, who doesn't put a 1/2" drive impact on the manifold bolts and just zips them out in any convenient sequence. It makes no difference - the manifold will not warp. Just pop the bolts out, No problem.
So you could remove any single bolt and put it back in and torque it down and there wouldn't be a problem.
As long as the others are sufficiently tight.........
#1 most common novice mistake is not torquing the bolts via the pattern enough times......there is no "enough times" spec......you just keep doing it til they are snug....and don't murder them
#2 most common novice mistake is not using PTFE sealer on the threads of the bolts so oil can leak past them.......
#3 most common novice mistake is using too long of a bolt in the positions that are right on top of the pushrod.....which rub and gall the pushrod and cause abnormal running.
I have seen all three of these at least 20 times or more over the years........
#1 tip I give to people working on their own stuff....."It is more important to know why you are doing a step than what the step is.....if you know how and why it does what it does, you will breeze through everytime".
Another tip is to make sure the bolts thread in by finger. Had an eddy intake that the rear two on one side would start a bit but you had to run em down with a wrench/ratchet. Was enough to distort the flange that those runners didn't seal as good. Simple fix was to enlarge the holes a bit.
Jebby
what sealant do you recommend? I found a Permatex that has PTFE, but it doesn’t say high temperature. Do you need high temperature sealant for these?
