'69 fuel pump problem
Old Dec 26, 2002 | 01:52 PM
Larry Cottingham's Avatar
Larry Cottingham
Default '69 fuel pump problem
Working on a '69 small block and it needs a fuel pump. I installed one from the Chevy place and it had a warning to install the correct pump on '69s. The dealer said this pump would fit. I installed it and it promptly broke the lever off. What pump do I need? Where is the best place to get a reliable pump(tried one from Pep boys on my '77 and it didn't last long).
Thanks for the help
Larry C.
Old Dec 26, 2002 | 02:04 PM
Brettmc's Avatar
Brettmc
Default Re: '69 fuel pump problem (Larry Cottingham)
If you're not worried about originality, get an electric fuel pump. I've got one. It makes a little noise that you can't hear after those 40-series Flows fire up.
Old Dec 26, 2002 | 02:20 PM
Larry Cottingham
Default Re: '69 fuel pump problem (Brettmc)
great idea, where did you mount yours?
Larry C.
Old Dec 26, 2002 | 04:08 PM
Brettmc's Avatar
Brettmc
Pass side next to coolant recovery tank. Minor rerouting of fuel lines and ignition voltage hookup required. Other than that, simple. I've got a little fuel pressure gauge at the fuel line/holley dual line junction. It usually runs around ~7 lbs.
Old Dec 26, 2002 | 05:20 PM
Larry Cottingham
OK thanks alot.
Larry C.
Old Dec 26, 2002 | 06:42 PM
Surfer69's Avatar
Surfer69
The dealers are giving you wrong pump. I had same problem, the pump is for big block ( I know some say there is no difference, but there is) and has something different with the arm. Had to get mine from performance shop to get right one. Do a search I think I had correct number you need.
Old Dec 26, 2002 | 06:47 PM
Ryan77's Avatar
Ryan77
Default Re: '69 fuel pump problem (Surfer69)
I'm not sure if it will work for your '69 SB, but I run the Holley 110gph pump on the '77 SB.
Old Dec 26, 2002 | 06:58 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
The main difference between the 69 pump and pumps from later models is that it has no fuel return integral to the pump itself. Fuel return comes off exit the fuel filter. Later model 'vettes used a fuel return integrated into the pump itself. When I installed my ZZ-4 in my 69, I used a 69 style pump without the integrated return line. I hooked it and just plugged the return line and used a single exit fuel filter. It ran 10 minutes and the lever broke. I put on a fuel pump from Autozone for a 1970-78 model SBC Corvette and it has run fine for the last 500 miles. This pump has the integrated return line out the bottom of the pump, I used the "S" shaped return hose for a 1970 and a custom bent "Lar's" main fuel line going to a single outlet filter to the carb.
PS If you are going to put an electric pump in, put it back at the tank! Electric pumps are designed to "push" fuel, not "pull" it.
To '69 fuel pump problem
