Death wobble
Old Dec 24, 2021 | 05:58 PM
Steve Kistler's Avatar
Steve Kistler
Default Death wobble
My 79 L82 has all new bushing,shocks,coil springs,tie rod ends,bearings,steering damper and ball joints. I hit a depression in the road at 40mph and the front end shook violently until I got slowed to 15 mph. I had it aligned a few months ago. It doesn’t do it hitting bumps or even potholes but does every time at that place in the road. Anyone ever experience that and what was the cause and or cure? I used that expression based on what someone else called it.Thanks
Old Dec 24, 2021 | 06:06 PM
gjohnson's Avatar
gjohnson
I'd say idler arm OR somethings loose
Old Dec 24, 2021 | 06:16 PM
Steve Kistler
Default I wish
I have been through every part of the suspension and come up with nothing. The only two things I thought that could possibly be Maybe is the steering box(although it steers fine normally) or the rag joint. Hopefully someone has had this happen and knows the cure. Very scary!
Old Dec 24, 2021 | 07:50 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I once had a similar Shake with a 70's Impala I owned many years ago.
It turned out to be the idler arm as suggested above.
And your C3 does not have a steering damper. Perhaps your speaking of the power steering cylinder.
Old Dec 24, 2021 | 07:57 PM
4-vettes's Avatar
4-vettes
Oh, And when the rag joint goes, it's real scary all the time, not just hitting a depression. Steering goes way loose with tons of slop. I know, I blew one years ago.
Steering box could also add extra play if worn. But the shake you describe sounds like a idler arm that's worn. And should have been caught when your alignment was done.
And also the other possiblility of something has come loose. You say a number of parts have been replaced recently. I would be double checking every nut and bolt.
Old Dec 24, 2021 | 08:01 PM
Steve Kistler
My mistake,slave cylinder and valve. Thanks I will in fact revisit the idler arm one more time.
Old Dec 24, 2021 | 08:34 PM
4-vettes's Avatar
4-vettes
Idler arm should feel stiff to move by hand. unhook it from the draglink and check it for freedom of movement.
Old Dec 24, 2021 | 09:15 PM
64drvr's Avatar
64drvr
St. Jude Donor '15
Whar’s your caster setting? Death wobble can be a trait of not enough negative caster.
Old Dec 24, 2021 | 09:35 PM
Steve Kistler
I would like to thank everyone for the information. I do have the car up on jack stands and with the advice of several members I ordered a new idler arm and will go from there. I don’t know my caster setting but I do know there was more play then I initially thought in the idler arm. Merry Christmas to all and to all a good night.
Old Dec 24, 2021 | 10:38 PM
4-vettes's Avatar
4-vettes
Good on ya Mate! (As we say in Australia.) There should be NONE play in an idler arm. Should feel stiff when moving by hand. Moves, but not readily.
Old Dec 24, 2021 | 11:23 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
And for excessive loosenes/slop. Bad shocks will cause a scary vibration (rare broken engine mount)
Broken weld?
Old Dec 25, 2021 | 07:55 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If it would happen in a shalllow long turn I would say caster. You may hae found it with your idler arm. Do you have power steering?
Old Dec 25, 2021 | 10:04 AM
Fly skids up!'s Avatar
Fly skids up!
Check if the alignment shims are still there. Sometimes they forget to tighten things up.
Old Sep 20, 2025 | 12:15 AM
doktor_g's Avatar
doktor_g
3rd Gear
Default Resolution?
Steve,
I have an identical problem with my 77. Was it the idler arm? I just had all bushings replaced and its still there. They gave me a castor angle of 4%. Would love to know if this worked.
Thanks everyone
G
Old Sep 20, 2025 | 12:36 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Originally Posted by doktor_g
Steve,
Thanks everyone
G
FYI, you are looking for an answer from someone who hasn't been on the fourm in a year... it's always better to start a new thread than open an old one
Old Nov 10, 2025 | 06:22 PM
doktor_g's Avatar
doktor_g
3rd Gear
this was it for my 1977 death wobble.
It was the idler arm
Old Nov 10, 2025 | 06:32 PM
Chambered's Avatar
Chambered
This happened to me in a Ram pickup (2 WD) about 2000. Turned out it was the tires that were worn & waaay out of balance. Everything was tight in the front end & I even put new shocks on the front & nothing changed until I put new tires on it.
Old Nov 11, 2025 | 07:44 AM
JavaJolt78's Avatar
JavaJolt78
4-Vettes
Great posts and just for future reference when I pass my 78 on the my grandie can you send/post a pic of that Infamous Idler Arm??
JJ78
To Death wobble
