oil pressure port
Old Dec 30, 2021 | 11:16 AM
69vette427/435's Avatar
69vette427/435
Default oil pressure port
Having trouble putting fitting in for oil gauge. Does anyone know the thread size ? thinking the threads might be messed uo.
Old Dec 30, 2021 | 11:23 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
On the gauge is a specific nut and ferrule that you have to get from a Vette supplier....the Auto Meter style kits will not work......
The nut and ferrule may be available somewhere else but I have never been able to find one.....
Jebby
Old Dec 31, 2021 | 11:06 AM
69vette427/435
Default revised
My bad. I asking about the thread size on the engine block. i think the threads might be messed up. Can't get the brass adaptor to screw in.
Old Dec 31, 2021 | 11:23 AM
fstntq's Avatar
fstntq
Tough to imagine threads on the block side being buggered but stranger things have happened.
Try some other bolts you have laying around to see if the thread size is different. (I'd think a US standard with non fine pitch) Double check your insert to make sure its "starter thread" is not buggered as well.
Lastly get a tap and die set to chase the block threads if needed.
Old Dec 31, 2021 | 11:46 AM
lars's Avatar
lars
The oil pressure port threads in the block are 1/8" NPT. Don't try to thread a bolt into the port as suggested above - that'll screw it up bad.
Lars
Old Dec 31, 2021 | 12:14 PM
69vette427/435
ok thanks
Old Dec 31, 2021 | 12:47 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yup, tapered pipe thread
Old Dec 31, 2021 | 01:10 PM
fstntq's Avatar
fstntq
While NPT is unique compared to a straight thread, I didn't offer the OP to put a wrench on it.
Just like he knows his current one doesn't fit, he would have figured out pretty quickly that my advice wouldn't either long before he'd
have made it worse. I guess I'm still more used to working on more modern and non US car which use a standard thread for these fittings and sensors.
Lars
Old Dec 31, 2021 | 07:00 PM
lionelhutz's Avatar
lionelhutz
Didn't say to use a wrench, but didn't say not to either....
To oil pressure port
