1970 LT1 header removal
Old Jan 9, 2022 | 03:30 PM
liv2ryd's Avatar
liv2ryd
Default 1970 LT1 header removal
Last year I purchased a '70 LT1 that the previous owner had done quite a bit of engine work to. The whole exhaust system had been changed over, starting with Hooker headers, 3" pipes w/crossover, and fairly raucous mufflers with turn-down tips. Fortunately, he saved the original and correct cast iron manifolds, and a stock-type system along with the correct square tips. The engine work was quite extensive, with a cam that was way over the top and pulled 5" or less of vacuum and would barely idle. I had the cam replaced to replicate a stock LT1 cam, and now am looking at the exhaust system. This car is completely numbers matching and correct, and I am much more interested in preserving the stock look of the car to the best degree I can. Looking at the headers today, it would appear to be quite a rasslin' match to get them out, particularly the driver's side. I do have a lift. Has anyone removed headers from an early C3 small block, and what gymnastics were required?
Old Jan 9, 2022 | 04:00 PM
Gordonm's Avatar
Gordonm
They actually come out pretty easily. If you have a lift they will come out the bottom wit ha little wiggling. The 1 5/8 Hookers almost drop out. The 1 3/4 are a little more difficult but still slide out without issue. You may have to remove the starter if it is the stock one. I know with mini starters they can be left in. Pulling the plugs makes it a little easier as it gives you a little more wiggle room.
Old Jan 9, 2022 | 04:30 PM
Dirty Dalton's Avatar
Dirty Dalton
Sawzall. Piece of cake.
Old Jan 9, 2022 | 05:03 PM
stingr69's Avatar
stingr69
Gotta pull the clutch bell crank.
To 1970 LT1 header removal
