What is the part number for the 1970 Transmission Controlled Spark (TCS) Switch located on the passenger side head
UPDATE: GM # 3961573, Its a two terminal temp sensor, with the same dark green wire connected to both terminals
This switch controls the temperature range that will operate the solenoid allowing vacuum advance to the distributor. It also has a switch to ensure the car is in 4th gear for this to activate.
TCS is an electric/vacuum system… There are actually two switches; a temperature switch in the head (which is what you are looking for) and an electricity driven (contact) switch in the transmission. This is all tied into a solenoid that that controls distributor vacuum depending upon temperature and transmission gear position. For 1970, the TCS system limits full advance until 3rd and 4th gear, for 1971-1972, full advance is limited to 4th gear.
Regards,
Stan Falenski
Stan
72 was the year the TCS was 4th gear only. CEC for 71 3 and 4th would get Vacuum.
