Best FI option for small block
I am planning to upgrade my 1969 to fuel injection in the next few months. It currently has a fairly low mileage 383 and is carbureted. I have a 73 and 75 that I have put LS engines in and I have become sold on fuel injection. Not ready to do the LS swap in the 69 but would like to take the baby step to FI on the existing engine. I know what needs to be done for the tank to get 58psi fuel to the engine, what I am looking for is the parts I need on the engine, I would like to have the distribute controlled by an ECU, so I think I need this:
https://www.summitracing.com/parts/fif-30005
I was hoping to use an HEI distributor with mechanical tach drive as part of this setup if possible.
Any advice is appreciated.
Scott
Personally I'm partial to the Holley EFI systems because they seem to keep supporting them longer than others. But I've never used a FiTech/FAST/Edelbrock/etc so can't say there's anything wrong with them.
Consider sequential port injection if you have a beefy cam as it will idle better and have better drivability than TBI.
As for the distributor just get a 75-77 electric tach and swap your old face plate over (or buy a new face plate). I got a face plate for a '69 350/350 with a 6K redline and the correct early green numerals. Think I paid $30 for it.
I have a Holley Stealth Sniper with a Holley OEM Fuel Tank Module on my 427 and they work great. I am getting ready to connect the timing to the system as well so the Holley Software will control both fuel and timing on the 427. I have a mechanical Tachometer so I needed to keep my MSD Billet Pro Distributor with the tach drive on it.
The Holley OEM Fuel Tank Module was the easiest part to install and took less than 1/2 hour. The electric fuel pump, Fuel pressure Regulator and the Fuel level sending unit all fit inside the fuel tank along with the piece of Holley Hydra Mat that attaches to the end of the fuel pump.
If you are concerned about parts fitting properly then you might look into your options. I purchased my EFI system thru EFISYSTEMPRO who is located in Florida and will give you incredible support for 2 years after the purchase. The guys there know their EFI systems and can help you if you have any questions. I actually thought very carefully about the ProFlow 4 system as it looks like a nicely put together part. In the end it was "Who will help me if I run into problems" that won me over to the Holley Stealth Sniper. I had planned on buying a new tank but the guys at Efisystempro were able to sell be a complete system for less than I had budgeted for the system.
I saved Hundreds over what I expected to cost and the system is great for a throttle body.
I pondered getting one of those holley electric fuel pumps that come in from the bottom..... sounds pretty wonderful, but I had time so I modified a Stainless Steel 1982 sending unit and made a pump support for a cannister-pump that comes in, and out, from the top. I did this because I did not want to deal with emptying the gas tank to replace the electric fuel pump (if it ever came to that).
On my 1968 I am still using a MSD Billet Pro Tach with mechanical tach drive but don't really "need" the cable with the Tach supplied on the Holley Handheld. I want one of Holley's 6.7" Touch-screens mounted on my dash in the center console. I just love their display tricks and their software is quite powerful with a lot of potential. It will control the timing, fueling, cooling and my Water/Methanol Injection system all to make and keep the 427 a "happy" 427.
The Holley Stealth Sniper fits on my 427 with an Edlebrock Performer RPM Air gap dual plane intake using a factory L88 Hood. I am also using the same intake parts as shown above by zwede in those beautiful pictures of the L88 parts on that Red Corvette. It is a bit snug using the factory seals on my C3 but still seals to the hood effectively. The stealth version is designed to look more like a carburetor and it does fit nice and snug under the drop base that I last used on a Double Pumper. It might be the shorter of them, it is a bit taller than my old Holley Double Pumpers but works great. It even starts in the cold weather now....
That Red C3 is a beautiful example of what a big block running the Sequential Fuel Injection looks like. I was wondering what it would look like under the L88 parts. Is the cold air intake still functional? How does it drive? Is it worth the difference over a normal throttle Body system? My Holley dealer is more than happy to try and sell you anything you can dream of. That is a really nice installation! Thanks for sharing it with us!
Removing the 1/2" from the top of the intake might be a good idea on my C3 as well. I want to have a professional, drill and tap my intake as well for the Water/Methanol injection system nozzles. I guess I will pull it when it warms up a bit later in the spring.
My wife had a GM Pickup with a TBI system and it worked great for 200k miles. On the Corvette I am still up in the air. My system keeps the A/F ratio right on the money and that is significant. I want to verify the A/F ratios on the UN-monitored side as well before I assume all is going well.
Once at Corvettes@Carlisle a crew from Speed-Vision started filming my Corvette. They had assumed that it was a real L88 since it had some of the right parts (along with a heater and radio). They were surprised to find that I drove it there and was driving it home. My C3 is painted the 1969 Color Daytona Yellow and is a convertible. I have seen the episode play online with my Corvette being scrutinized by their cameras. My engine looks clean and straightforward but does not have the little Snowflakes on the cylinder heads like a L88 would. I told the crew that it was a L88 Dupli-car for all practical purposes and that it is running the L88 Pistons and compression. I have never mis-represented my Corvette as a factory L88 Corvette. I do have several parts from a real L88 on my Corvette.
I noticed a fuel regulator snuggled up against the water pump. Holley, Aeromotive? The fuel system I'm putting together for my 70 has an Aeromotive A1000 fuel pump, Aeromotive filters, EFI regulator, and a speed controller. The reguator has a conversion kit to rebuild it for carburetors.
My 68 ZZ4 has a HEI distributor with a mechanical tach drive. I use the HEI electronic tach signal to drive the 68's Aeromotive pump speed controller.
I would not even install the EFI if you are not going to use the Timing control......
Jebby
The first is a 66 Mustang with a 289, for it I used FITech and their command center canister, the command center gave me some issues at first, but it's been so long that I don't remember exactly what they were. I do believe there were several other folks having issues with these as well, as this was a one of their new products at the time. Once everything was sorted, the unit has worked fine (over 5 years).
The second is a 72 Challenger with a 340, for it I used the Sniper with inline pump. No issues initially, however, I had to mount the pump right next to the muffler and eventually the pump started sounding weak (I believe due to heat). I then went with a drop in pump/tank from Tanks, Inc. This also alleviated some concerns I had over my return line, as the original style tank used an oddball type vent system. It has ran fine since (around 4 years).
The third is a 72 Corvette with a 350. Again I went with the Sniper, but had some initial issues on this one. Fuel leak around the base of the throttle body onto the intake, had to send it back to Holley for repairs (reported as a ripped o-ring), took around 6 weeks to get it back from repairs. I'm currently having an issue with the car dying after about 30 minutes of drive time, but I don't think it's related to the EFI, though I don't know what is causing it. You'll be driving and it's just like you turned off all of a sudden. New ignition switch didn't help, coil checked good (both cold and hot), but I'm putting another in anyway to be sure. If they doesn't fix it, I'll swap the distributor again.
Easy to find a HEI distributor with mechanical tach output. If my problems end up being due to the distributor then I would say I'm not a good source of info on that, so will so no more.
I don't see it being mentioned as much anymore as I think most manufacturers are now more clear in their instructions and people are aware, but any unit requires a clean 12v source through both start & run. I believe it's easy enough to find a source on the Corvette, but wasn't easy on the Challenger, so I used a timing circuit relay to provide signal to the EFI. They are easier to set-up than they used to be (use an app now, whereas you previously had to use a trigger wire on a 12v source to select the program), can be installed in an easily accessible area of your choosing (so don't have to crawl under the dash), a lot of programming options, and they seem to use quality components. I get them off amazon, the company is called Timers Shop.
